    Hey guys im having issues with my car and I was told to run this test. Any feedback is appreciated. Thanks!
    Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST
    Start : 29.04.2024 19:15:36.2
    Nr 1( 1) : 29.04.2024 19:15:36.3
    apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 59 00 3B .;
    EVAN_SOLLWERT = 52 00 34 .4
    EVAN_ISTWERT_EINH = Grad KW
    EVAN_SOLLWERT_EINH = Grad KW
    Nr 2( 1) : 29.04.2024 19:15:41.7
    apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
    JOB_STATUS = OKAY
    Nr 3( 1) : 29.04.2024 19:15:47.0
    apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
    JOB_STATUS = OKAY
    EVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
    EVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
    EVAN_VERSTELLZEIT_FRUEH_EINH = ms
    EVAN_VERSTELLZEIT_SPAET_EINH = ms
    Nr 4( 1) : 29.04.2024 19:15:53.3
    apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
    JOB_STATUS = OKAY
    EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet
    Nr 5( 1) : 29.04.2024 19:16:07.7
    apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 48 00 30 .0
    AVAN_SOLLWERT = 20 00 14 ..
    AVAN_ISTWERT_EINH = Grad KW
    AVAN_SOLLWERT_EINH = Grad KW
    Nr 6( 1) : 29.04.2024 19:16:13.0
    apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 49 00 31 .1
    Nr 7( 1) : 29.04.2024 19:16:18.3
    apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
    JOB_STATUS = OKAY
    AVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
    AVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
    AVAN_VERSTELLZEIT_FRUEH_EINH = ms
    AVAN_VERSTELLZEIT_SPAET_EINH = ms
    Nr 8( 1) : 29.04.2024 19:16:24.6
    apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
    JOB_STATUS = OKAY
    AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet
    Stop : 29.04.2024 19:16:39.7
    Dauer : 63.5 s
      Can't interpret from this, your output is missing required information (solenoid coil pack has likely failed).
        Your desired values our out of specification which is very weird!
        Any error codes?
          Any error codes?
          Hello!
          I had a p0011 and p0014. Then I changed my solenoid pack, cleaned the valve body and changed the o rings. After that I was getting a p0012 code but my p0011 and p0014 disappeared. Also my car would not stay on as it would die when coming to a stop.
          ended up getting the car towed to a shop. We will see what they say.
            These are camshaft position sensors. Once these don't work, the VANOS test won't work.
              Unzip the attachment,
              place it in C:\EDIABAS\ECU
              start Tool32
              Click the 2nd [OPEN] icon
              open MSS54_VANOS_Test.tst
              Press F8 to run all tests
              A result screen similar to the quoted code text below should appear *tested only with bench set up! Not with a running engine
              Code:
              Start : 18.06.2020 19:57:00.5
              Nr 1( 1) : 18.06.2020 19:57:00.6
              JOB_STATUS = OKAY
              EVAN_ISTWERT = 60 00 3C .<
              Nr 2( 1) : 18.06.2020 19:57:06.0
              JOB_STATUS = OKAY
              Nr 3( 1) : 18.06.2020 19:57:11.3
              JOB_STATUS = OKAY
              Nr 4( 1) : 18.06.2020 19:57:17.5
              JOB_STATUS = OKAY
              Nr 5( 1) : 18.06.2020 19:57:32.0
              JOB_STATUS = OKAY
              AVAN_ISTWERT = 0 00 00 ..
              AVAN_SOLLWERT = 0 00 00 ..
              Nr 6( 1) : 18.06.2020 19:57:37.3
              JOB_STATUS = OKAY
              Nr 7( 1) : 18.06.2020 19:57:42.5
              JOB_STATUS = OKAY
              Nr 8( 1) : 18.06.2020 19:57:48.9
              JOB_STATUS = OKAY
              Stop : 18.06.2020 19:58:03.3
              Dauer : 62.9 s
              Very cool!
              Any chance you could whip up something for VANOS adaptions reset in INPA? It's a bit a chore to have to fire up DIS for every Vanos rebuild.
              IG: @limited.slip
              Mystic Blue / M-cloth E46 M3 Coupe S54 6MT
              A̶l̶p̶i̶n̶e̶ ̶W̶h̶i̶t̶e̶ ̶/̶ ̶B̶l̶a̶c̶k̶ ̶E̶4̶6̶ ̶3̶2̶5̶i̶ ̶T̶o̶u̶r̶i̶n̶g̶ ̶S̶5̶4̶ ̶6̶M̶T̶
              Imola Red / Alcantara / Cloth E46 330i ZHP Sedan S54 6MT
              Titanium Silver / Black E39 540i M-Sport
              Touring S62 6MT
              Alpine White / Black E90 M3 M3 S65 7DCT
                Originally posted by kaiv View Post
                Very cool!
                This tool is even faster than INPA
                As per the title I've just put together a new utility for you guys that can do a few basics on the DME. Click image for larger version Name: DME_Utility-Release.png Views: 0 Size: 30.8 KB ID: 20329 Click image for larger version Name: DME_Utility-Release-Codes.png Views: 0 Size: 17.7 KB ID: 20330 The software can be used
                  Doesn't resetting all engine adaptations on INPA include the VANOS?
                    Very cool!
                    I'm busy integrating VANOS test in INPA and some more functionalities. Sure to add that one as well.
