    Hey guys im having issues with my car and I was told to run this test. Any feedback is appreciated. Thanks!
    Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST
    Start : 29.04.2024 19:15:36.2
    Nr 1( 1) : 29.04.2024 19:15:36.3
    apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 59 00 3B .;
    EVAN_SOLLWERT = 52 00 34 .4
    EVAN_ISTWERT_EINH = Grad KW
    EVAN_SOLLWERT_EINH = Grad KW
    Nr 2( 1) : 29.04.2024 19:15:41.7
    apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
    JOB_STATUS = OKAY
    Nr 3( 1) : 29.04.2024 19:15:47.0
    apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
    JOB_STATUS = OKAY
    EVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
    EVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
    EVAN_VERSTELLZEIT_FRUEH_EINH = ms
    EVAN_VERSTELLZEIT_SPAET_EINH = ms
    Nr 4( 1) : 29.04.2024 19:15:53.3
    apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
    JOB_STATUS = OKAY
    EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet
    Nr 5( 1) : 29.04.2024 19:16:07.7
    apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 48 00 30 .0
    AVAN_SOLLWERT = 20 00 14 ..
    AVAN_ISTWERT_EINH = Grad KW
    AVAN_SOLLWERT_EINH = Grad KW
    Nr 6( 1) : 29.04.2024 19:16:13.0
    apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 49 00 31 .1
    Nr 7( 1) : 29.04.2024 19:16:18.3
    apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
    JOB_STATUS = OKAY
    AVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
    AVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
    AVAN_VERSTELLZEIT_FRUEH_EINH = ms
    AVAN_VERSTELLZEIT_SPAET_EINH = ms
    Nr 8( 1) : 29.04.2024 19:16:24.6
    apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
    JOB_STATUS = OKAY
    AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet
    Stop : 29.04.2024 19:16:39.7
    Dauer : 63.5 s
      Can't interpret from this, your output is missing required information (solenoid coil pack has likely failed).
        Your desired values our out of specification which is very weird!
        Any error codes?
          Any error codes?
          Hello!
          I had a p0011 and p0014. Then I changed my solenoid pack, cleaned the valve body and changed the o rings. After that I was getting a p0012 code but my p0011 and p0014 disappeared. Also my car would not stay on as it would die when coming to a stop.
          ended up getting the car towed to a shop. We will see what they say.
            These are camshaft position sensors. Once these don't work, the VANOS test won't work.
              Unzip the attachment,
              place it in C:\EDIABAS\ECU
              start Tool32
              Click the 2nd [OPEN] icon
              open MSS54_VANOS_Test.tst
              Press F8 to run all tests
              A result screen similar to the quoted code text below should appear *tested only with bench set up! Not with a running engine
              Code:
              Start : 18.06.2020 19:57:00.5
              Nr 1( 1) : 18.06.2020 19:57:00.6
              JOB_STATUS = OKAY
              EVAN_ISTWERT = 60 00 3C .<
              Nr 2( 1) : 18.06.2020 19:57:06.0
              JOB_STATUS = OKAY
              Nr 3( 1) : 18.06.2020 19:57:11.3
              JOB_STATUS = OKAY
              Nr 4( 1) : 18.06.2020 19:57:17.5
              JOB_STATUS = OKAY
              Nr 5( 1) : 18.06.2020 19:57:32.0
              JOB_STATUS = OKAY
              AVAN_ISTWERT = 0 00 00 ..
              AVAN_SOLLWERT = 0 00 00 ..
              Nr 6( 1) : 18.06.2020 19:57:37.3
              JOB_STATUS = OKAY
              Nr 7( 1) : 18.06.2020 19:57:42.5
              JOB_STATUS = OKAY
              Nr 8( 1) : 18.06.2020 19:57:48.9
              JOB_STATUS = OKAY
              Stop : 18.06.2020 19:58:03.3
              Dauer : 62.9 s
              Very cool!
              Any chance you could whip up something for VANOS adaptions reset in INPA? It's a bit a chore to have to fire up DIS for every Vanos rebuild.
              IG: @limited.slip
              Alpine White 1 Series M Coupé
                Originally posted by kaiv View Post
                Very cool!
                This tool is even faster than INPA
                As per the title I've just put together a new utility for you guys that can do a few basics on the DME. Click image for larger version Name: DME_Utility-Release.png Views: 0 Size: 30.8 KB ID: 20329 Click image for larger version Name: DME_Utility-Release-Codes.png Views: 0 Size: 17.7 KB ID: 20330 The software can be used
                  Doesn't resetting all engine adaptations on INPA include the VANOS?
                    Very cool!
                    I'm busy integrating VANOS test in INPA and some more functionalities. Sure to add that one as well.
                      Guys, anyone have 288/280 12.5 lift cams and who has done vanos test?
                        So I had a question about the Vanos test.
                        One of my cars is starting to have the marbles in a can sound at low RPM with a load on the engine. Sounds like pinging but it's a fresh rebuild. It's the same sign you're hearing cars when you run low octane fuel when you get the marbles in the canned sound.
                        Doing some searching I came across several instances where they mentioned timing being off.
                        I have never heard the pinging before until recently, so my guess is maybe it would probably go away if I reset Vanos adaptations and then probably come back
                        So if I want to run the Vanos test, should I run it now and it's current state or should I run it after I reset adaptations?
                        And would a successful vanos test mean that the engine is properly timed
                        I also had these Shadow codes. I never saw a check engine light but I decided to check codes today and saw these Shadow codes. Inlet Vanos retard valve errors
                          Doesn't matter
                          Was the engine rebuild with different than OEM components?
                            Doesn't matter
                            The engine was built with all BMW parts from FCP Euro. The reason I question anything is because I used a non-bmw timing, bridge and pins when I did the timing.
                            The engine has been running great with no other issues other than this weird pinging sound that just started coming out of nowhere
                            I'm on the CSL tune with the non CSL Vanos offsets that I found on these forums.
                            If the Vanos test comes back clean then I'm going to try using a stock CSL too without modified Vanos offsets and see if that changes anything.
                              pinging sounds more like cumbustion is not OK. Would check fuel trims and knock adaption too.
                                This is what my adaptations currently are using ecuworx
                                Click image for larger version  Name:	PXL_20241023_115725134.jpg Views:	0 Size:	173.5 KB ID:	282043
                                This is my first and 2nd vanos test run back to back oil temp was normal and i just came back from daycare drop off driving for 45 min with some spirited driving in between after dropping kids off of course.
                                Code:
                                Start     : 23.10.2024 09:05:37.3
                                Nr 1(  1) : 23.10.2024 09:05:37.4
                                apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG","","")
                                  JOB_STATUS                      = OKAY
                                  EVAN_ISTWERT                    = -1           FF FF FF FF  ÿÿÿÿ
                                  EVAN_SOLLWERT                   = -10          FF FF FF F6  ÿÿÿö
                                Nr 2(  1) : 23.10.2024 09:05:42.8
                                apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG","","")
                                  JOB_STATUS                      = OKAY
                                  EVAN_SOLLWERT                   = 75                 00 4B  .K
                                Nr 3(  1) : 23.10.2024 09:05:48.2
                                apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT","","")
                                  JOB_STATUS                      = OKAY
                                  EVAN_VERSTELLZEIT_FRUEH         = 319                01 3F  .?
                                  EVAN_VERSTELLZEIT_SPAET         = 261                01 05  ..
                                Nr 4(  1) : 23.10.2024 09:05:54.5
                                apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT","","")
                                  JOB_STATUS                      = OKAY
                                Nr 5(  1) : 23.10.2024 09:06:08.9
                                apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG","","")
                                  JOB_STATUS                      = OKAY
                                  AVAN_SOLLWERT                   = -10          FF FF FF F6  ÿÿÿö
                                Nr 6(  1) : 23.10.2024 09:06:14.3
                                apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG","","")
                                  JOB_STATUS                      = OKAY
                                  AVAN_SOLLWERT                   = 55                 00 37  .7
                                Nr 7(  1) : 23.10.2024 09:06:19.6
                                apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT","","")
                                  JOB_STATUS                      = OKAY
                                  AVAN_VERSTELLZEIT_FRUEH         = 226                00 E2  .â
                                  AVAN_VERSTELLZEIT_SPAET         = 211                00 D3  .Ó
                                Nr 8(  1) : 23.10.2024 09:06:25.9
                                apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT","","")
                                  JOB_STATUS                      = OKAY
                                Stop      : 23.10.2024 09:06:41.0
                                Dauer     : 63.7 s
                                Code:
                                Start     : 23.10.2024 09:09:47.8
                                Nr 1(  1) : 23.10.2024 09:09:47.9
                                  JOB_STATUS                      = OKAY
                                Nr 2(  1) : 23.10.2024 09:09:53.3
                                  JOB_STATUS                      = OKAY
                                Nr 3(  1) : 23.10.2024 09:09:58.6
                                  JOB_STATUS                      = OKAY
                                  EVAN_VERSTELLZEIT_FRUEH         = 321                01 41  .A
                                  EVAN_VERSTELLZEIT_SPAET         = 258                01 02  ..
                                Nr 4(  1) : 23.10.2024 09:10:05.0
                                  JOB_STATUS                      = OKAY
                                Nr 5(  1) : 23.10.2024 09:10:19.5
                                  JOB_STATUS                      = OKAY
                                Nr 6(  1) : 23.10.2024 09:10:24.8
                                  JOB_STATUS                      = OKAY
                                Nr 7(  1) : 23.10.2024 09:10:30.3
                                  JOB_STATUS                      = OKAY
                                  AVAN_VERSTELLZEIT_FRUEH         = 251                00 FB  .û
                                Nr 8(  1) : 23.10.2024 09:10:36.6
                                  JOB_STATUS                      = OKAY
                                Stop      : 23.10.2024 09:10:51.7
                                Dauer     : 63.9 s
