MSS5x Binary Modification Tool Update
    This is amazing, THANK YOU. So I can move my non ready to either the O2 heater or Evap.
    I've been drive cycling my butt off , for a few days,and nothing seems to be working.
    I downloaded Torque Pro on my phone, so I can the readiness without going to the actual emissions place..pantone know of a cheap compatible bluetooth adapter?
    I've used this one without issue: https://www.amazon.com/vgate-Bluetoo...365304&sr=8-13
    Should work with both iOS and Android.
      these cheap things work perfectly. Pay more for a us seller for faster delivery.
      Thanks so much!
        Thanks!!
          What is the difference between the Z4M Electric Fan settings vs the E46 M3 Aux Fan settings?
          Evolve Eventuri
            Z4M on the left, E46 M3 on the right
              Interesting how the M3 fan ramp is actually more aggressive
                Z4M on the left, E46 M3 on the right.
                Thanks Martyn. As Terra stated it appears the M3 values are more aggressive, wouldn't that work better in hotter climates? Are the Z4M fan values preffered for track use only? My M3 is my DD and the desert temps get up to 100-120 degrees, should I just keep the E46 M3 fan values?
                Evolve Eventuri
                  Thanks man! I just got it to adjust my throttle maps and change my IAT to CSL scaling
                  Budget CSL MAP Conversion
                    Hmmm.... I was planning on switching to Z4M electric fan settings since I had heard it was more aggressive than the M3 - going to max DC at a lower temperature... guess not?
                    -Brandon
                    2005 M3 BMW Individual Sterling Gray / Imola Red 6MT
                      Huh I also thought the Z4M values were more aggressive (more speed at lower temp). Made this to help visualize the differences based on the info Martyn provided.
Name:	E46 M3 vs Z4M Fan.png
                      Guess I'll stick with the M3 values?
                        This makes sense why I feel like my fan wasnt working very well last week. I wish I could adjust the fan duty cycle. Hey Martyn
                        this is great info guys. Martyn, you are awesome for producing this stuff to make tweaking things easier for us
                          Great update Martyn, I like the 1k idle speed under "General 2 (Cross Platform)", its like a "soft" launch control. 😎
                          Formally SWRTstang_M3 on M3forum.net with a join date of 07/2004
                            How do I backup a license to bring this over to a new computer?
                              Drop me an e-mail and I'll cut you a replacement license, no need to back it up.
                                So when I load my bin in the tool, the "idle speed" option is greyed out. Can i not adjust this with CSL ecu?
