The carbon slicktop thread
    dynamat makes a few different products including a roofliner. that being said, went with the oe stuff. makes a big difference even just tapping on the roof. would definitely not run it without something to dampen the noise
    OEM is what I went with. If I were going to skip it due to price or availability, I'd go with an adhesive backed melamine foam made for cars. I'd rather absorb the sound than dampen it from above, simply because of the weight.
    Noted. Went ahead and ordered it while it's still around.
    🔹 2001 M3 Laguna Seca Blue
    Instagram: link
    Build thread: link
      Another couple question.
      1. Why do body shops contract out the glass(front and rear windshield) work? What's the limiting factor that makes it need a specialist.
      2. Has anyone tried saving some dough by DIY'ing the windshield removal? It seems like a mild pain, but pretty easy. My front glass will need replacement anyways (rear is in good shape).
      Instagram: link
      Build thread: link
        Removing glass is significantly harder than you'd imagine, especially on older adhesive. My bet is body shops don't want the hassle.
        When I had my front glass removed to spray the car, the glass installer (not the body shop) installed the incorrect weather strip that frames the windshield. But I didn't realize it until the rolling chassis was back at my house. So I had a mobile vendor come to pull the glass and install the correct BMW trim / weatherstrip. The vendor that came was 1) very detail oriented 2) NOT from Safelite 3) an independent glass guy with fantastic tools and 25 years in the biz. He warned me that there was a 50/50 chance that the brand new fancy IR windshield that was just installed a week earlier would crack upon removal, as the original windshield did that was removed from the car to do the paintwork.
        It didn't crack, but even with his pro-quality tools, there is no way I'd want to try that job. You just can't fake experience with some jobs.
          Worked in a body shop. Hassle isn’t wanted and glass sitting around is getting broken. Dem boys ain’t gentle.
            I found a local guy who travels and does insurance glass work. I paid him to just remove my glass and reinstall. $85 a pop. He did it in like 10 mins. dude was a beast.
              I've done the roll cage, built the diff, replace the engine, 5 speed conversion, literally I've performed all of the labor and built most of my own parts - the only thing I have farmed out is body work and windshield R&R.
              Windshields are a black art. You can screw it up easily and you have to do 5-10 windshields to make up for 1 botched one. Kind of entertaining matching the big box places like safelite do the job. I wonder how those techs make money. The key is to find an independent guy that's been doing it for awhile, we will take 10 min and do it perfectly like Tonggi mentioned.
                Appreciate the input. I'm starting this project in a couple weeks.
                Any particular guidance you all would recommend to provide the glass installer to ensure they don't screw it up on removal or install. Mainly concerned with some of the power tools i've seen to remove glass, alignment, and sealing on install
                bigjae46 Tonggi oceansize Casa de Mesa
                Instagram: link
                Build thread: link
                  It's not that hard with the right tools, even with the wrong tools it can be done . I replaced the windshield on my e36 myself, granted it was already shattered, so I didn't have to worry about cracking it, but it was no worse once I got it out. Install was fairly straight forward, clean all the old adhesive out, clean, prep, and lay an even bead of adhesive, install the reveal around the glass and lay it in there. There were little rubber nubs on the frame to ensure it's spaced correctly, then throw a couple pieces of painter's tape on the top edge to keep it from sliding down till cured. No issues in the last 3-4 years since I did it.
                  On the e46, it was at the bodyshop for paint, so I had them install the carbon roof, they had a glass guy. I seriously considered DIYing that too.
                    Had a professional come today. Very happy with the service. No power tools, hacking, or banging up interior parts.
                    Both glass pieces came off cleanly. Will be replacing the front anyways.
                    Instagram: link
                    Build thread: link
                      Godspeed. Keep us posted fellow LSBer.
                        Curious what we all did with these drain hoses?
ID:	351199 Click image for larger version
                        Instagram: link
                        Build thread: link
                          IIRC, I just plugged the holes and called it a day. The drains are [obviously] useless on a slicktop.
                            Found an old pic. I couldn't find a pic where I capped them off, but I purchased an assortment of silicone caps off from McMasters or Amazon (can't remember) and just capped them similar to the red caps in the 2nd pic. If you measure the OD of the drain pipes, you can pick up the right size caps pretty easily.
                            Or... just leave them be. I can't imagine they'd be an issue if left open.
                            Click image for larger version  Name:	image.png Views:	0 Size:	1.03 MB ID:	351225
                            Click image for larger version  Name:	image.png Views:	0 Size:	903.0 KB ID:	351226
                              Thanks Casa de Mesa I figured, but was curious what others did since I didn't see them mentioned anywhere.
                              Instagram: link
                              Build thread: link
                                You bet. We need progress pics as they become available!!
