The carbon slicktop thread
    You bet. We need progress pics as they become available!!
    Things are happening.
    🔹 2001 M3 Laguna Seca Blue
    Instagram: link
    Build thread: link
      Nice!
        Some day I'll do that too !
        Love the pictures in this thread !
        2004 E46 M3 • TiAG / LSB nappa
          I keep thinking, I’ll do this someday when all the other problems with my car are fixed, but then I remember what car I’m talking about.
            Indeed. Good things. Very good things.
              I am curious with these carbon roof installs, do you have to deal with leaks or noises? How do you ensure it's sealed properly?
                Godspeed brother. Shoot me a text if you have any questions. (832) 3I2-474O
                Check out my DIY thread. I shined a light around the perimeter from the outside and made sure no light was coming thru on the inside. No leaks and no noises. You just have to take your time and do it right the first time.
                997.1 GT3 Carrara White/Black
                C43 AMG Diamond Silver/Red​
                  If anything (and if done correctly per SQ13 ) it is quieter without a 2x3' hole on the roof!
                    Thank you! Expect a text from me later this week. Would love to to clarify some things before superglueing this thing on. I also just added you on IG. I've been posting some clips to stories of all the "fun".
                    bhenderson def check out SQ's DIY. Not sure I would've tackled this myself without it. The idea is that the roof perimeter is sealed to water by panel bond. Then vibrations are handled just like the factory does by using windshield adhesive or similar between the roof bows and cf panel.
                    Instagram: link
                    Build thread: link
                      Anyone happen to have an extra slick top coat hanger bracket? Apparently they are NLA. I was able to order the right bracket and the roof bow, but no luck on the left bracket.
                      51168223047
                        51168223047
                        I would bet Mpartsworldwide has some
                          51168223047
                          I grabbed an extra set off a non-m slicktop and for the life of me can't find them. I'll PM you if I can dig them up.
                          Instagram: link
                          Build thread: link
                            Factory (steel) slicktop here. Can I install CSL roof rails with no drama? I don't plan on putting a roof rack on this car and I like the look of the rails without the doors.
                            I believe the threaded inserts are welded to the roof structure so I'm not sure if they would interfere. I don't want to cut anything if I can help it.
                            2003.5 SG/Grey
                              Yes you can install them
                                Aren't they NLA?
