HTE Performance IG has a preview of the TMS sound
Turner Motorsport CSL Airbox
Budget CSL MAP Conversion
Originally posted by Radekxpl View Post
Indeed it does sound very nice 👍06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
Originally posted by COVID-19 View PostMade good power too!
342 whp apparently with just megan headers, the TMS box, and HassanEido . No meaningful delta from stock since the car had a tune, headers, and AFE intake before, but still that's pretty exciting.Last edited by ATB88; 06-01-2020, 08:36 AM.
Originally posted by ATB88 View Postshameless ask: if anyone in/around LA has a spare IAT sensor lying around (any scaling) and is willing to part with it, I can install my airbox today :0 willing to drive to you and pay whatever you think is fair!06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
Originally posted by ATB88 View Postshameless ask: if anyone in/around LA has a spare IAT sensor lying around (any scaling) and is willing to part with it, I can install my airbox today :0 willing to drive to you and pay whatever you think is fair!2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 3
Got mine installed today! First things first: driving this thing at WOT with the top down through a mountain tunnel is f***ing bonks. 10/10 on that part.
Comments on fitment:
1. The fan shroud rubs against it at the front. I was very foolish and thought I could stick a few layers of shop towel pinned between the shroud and box at the contact point and go for my first drive and it'd be fine. I was wrong. Damage done. Is there anything I can do to repair this?
2. Getting the bottom ICV hose to connect to the front-bottom bung on the airbox was very difficult. In the end I had to reallly stretch the hose and connect it to the bung BEFORE pushing the throttle body boots onto the throttle bodies. Idk if this is sustainable for that hose.
3. The air shutoff valve is very hard to get connected to the bung on top of the box. You really have to force it, to the point that I thought I was going to break the box. And once it's on it, it honestly feels like it's going to pop back out. It hasn't yet, but still.
4. The way the bottom of the box is contoured (or more accurately the lack of any contours--it's flat), the bracket can't actually hook the rubber thing to hold that solenoid valve or whatever it is that's supposed to hang under the box. The arm of the bracket that's supposed to hook onto the grommet sits flush against the bottom of the box, there's no way to hook the grommet on, kinda useless. This was Turner's in-house replica bracket, not OE.
5. The small hose that connects all the way back down to the oil pan doesn't sit in its bung nearly as securely as it does on the stock box. On the stock box it's really locked in and you have to push the tabs from above to get it out. On this box you can get it back out pulling very lightly on the hose from the bottom. Makes me worry the hose might fall out on its own.
2-5 aren't huge deals, although I am concerned about longevity of the connectors/hoses on 2+3. But 1 is a big problem imo. Car drives great, have a few small drivability issues atm, but I suspect that those are tune related, see no reason why they would be the boxes fault.Last edited by ATB88; 06-02-2020, 11:58 PM.
Isn’t BuildJournal around there? They sell Iat Relocations.
Originally posted by ATB88 View PostGot mine installed today! First things first: driving this thing at WOT with the top down through a mountain tunnel is f***ing bonks. 10/10 on that part.
I had on my Karb. box as well. I had to file down the locking tabs on the shutoff valve to get it to seat on the box properly.
Problem # 1
Also you have to remove the driver's side splash shield for snorkel clearance on a Karb. box. Sounds like it also needs to come off for the
Turner box. You will either have to remove your top radiator hose or cut it off. I made one cut with a small handheld saw and it came off pretty easily and I didn't ruin the splash shield. But the correct way is to remove the top radiator hose.
Awesome man, that sound is something isnt it!!Last edited by Cubieman; 06-03-2020, 03:24 AM.2004 Silbergrau Metallic 6MT
I ripped my splash shield out. Lol didn’t want to disconnect the top hose.06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
For 4, can you bend the bracket a bit to get the rubber grommet on?
And yeah, CSLs don't have the driver's side shroud because of clearance with the snorkel. I had cut mine along these lines a while back and could get it on and off without removing the top radiator hose.
Now that I have a CSL airbox, I just don't run it2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Awesome, glad to hear that these aren't issues unique to the Turner box. Wish I'd realized ahead of time that the stupid shroud's not supposed to be there on a CSL, d'oh.
And yeah I did bend the bracket down to be able to hook the grommet on, but still not much space as the arm is pretty short. So I ziptied it lol.Last edited by ATB88; 06-03-2020, 01:22 PM.
