DIYs
This is a sticky topic.
    There will still be some spillage though, so be prepared.
    Will do thanks for the heads up!
      I'm looking for a oil filter housing gasket DIY. Anybody know of a good one? I've been reading the one by Pelican Parts, which is a good start.
      Specifically, I want to know if it's necessary to drain the oil. Trying to avoid that if at all possible.
      Highly recommend the Bavarian Autosport Viton OFHG. I do believe ECS carries it now.
      Also saw this post on torquing the housing.
      Evolve Eventuri
        This is the exact gasket I purchased from ECS! No brained to go with viton for this. Didn’t even know about it until I saw it referenced in a build journal post about the oil pressure valve.
        Excellent point on the torque method. I’ll hand tighten top 4 evenly, then do a Star pattern torque on the top 4 , and finish with the bottom 2.
          VANOS bolts replacement and oil pump disk replacement
            https://www.youtube.com/watch?v=9SkT2j3jsU0
            Just fyi, looks like they did the timing incorrectly. You're supposed to torque the hub bolts with the VANOS fully seated against the head, not with it off. Follow TIS or the Beisan procedure and you'll be good.
              That's my video. Car's been running fine for 30k miles
              If you put it back together the same way you took it off it's perfectly fine. If you're swapping parts and don't have a reference then the Beisan way is the way to go for sure.
                Could we add links to a valve adjustment DIY?
                Thanks!
                  S54 Vanos Info Thread
                  http://uploads.tapatalk-cdn.com/20170709/b427cc1ecdc0899673ce51539b3394e1.jpg http://web.archive.org/web/20180214064458im_/http://uploads.tapatalk-cdn.com/20170709/a40017b090c94ffa891574d94069c3c0.jpg Disclaimer: ( Most of the M3Forum links below do not work anymore ) Please read and completely understand the timing
                  Evolve Eventuri
                    Added
                      Is it just me or does the link for every DIY from “Replacing e46 side view mirror glass” down take you to this specific post??
                      (Note that this is only in Tapatalk, so I suspect it’s something weird for just me, but pretty odd)
                        As suggested by Casa de Mesa
                        My guide how to order genuine special tools based on the numbers in TIS.
                        Hello everyone, Occasionally I order some genuine BMW special tools as described in TIS. I find them to be of far better quality than some aftermarket replicas available, and it makes for easy repairs. At times, I have had issues finding the right part number to order the tools, since BMW decided to obfuscate this with their
                          BMW S54 WPC Treated Rod Bearing Kit Installation Instructions.
                          http://bd8ba3c866c8cbc330ab-7b26c6f3...n_-_Turner.pdf
                          Is it just me or does the link for every DIY from “Replacing e46 side view mirror glass” down take you to this specific post? (Note that this is only in Tapatalk, so I suspect it’s something weird for just me, but pretty odd)
                          I’m getting the same thing trying several DIY links using the Tapatalk App.
                          Evolve Eventuri
                            Great info in here!
                            2005 BMW M3 - Interlagos Blue
                              Thank you for this sticky! New to the forum and this saved my hours of searching. Just bought a 206k mile m3 that needs a lot of love 😅
                                Not sure if anyone on the forums has used this before.
                                But you can get service manuals for free for cars manufactured from 1982-2014 via "charm.li" in your browser.
                                /// 2004 SG/IR - Build Thread
