If you make a DIY thread that it seems like I miss and don't link here, please PM me a link to it!
Coding/Tuning
Intro to BMW Coding / Diagnosis and setting up Ediabas
Getting Started with NCS Expert
How to BDM MSS54/HP with FGtech Galletto 4
Converting an MSS54/HP into an MSS54HP CSL (H-bridge)
Flashing your SMG module with CSL Software + CSL Rev Matching and Torque Maps
Engine
Belts/Pulleys/Tensioners
Rod bearings
Thermostat & Water Pump Replacement
Cooling System Overhaul
Rod bearing replacement and front suspension refreshment
Header install
Extending O2 wiring for Section 1 with Cats
S54 Vanos info
Transmission
SMG to 6MT Conversion
E21 Transmission Mounts
CPV valve
Transmission Detent Compression Spring and Locking Pin Replacement
Differential
Fluid Swap
Steering
High Pressure P/S Hose
Z3 Steering Rack Retrofit
Suspension
Suspension setup
Suspension install videos
Chassis & Drivetrain
Flex Disc (Guibo)
Alternate Rear Subframe Repair Method
Subframe Plates
SLON Workshop front brace
Brakes
996 Brake conversion
Stereo/ICE
Stereo Wiring Guide
Other
Rear Quarter Panel Window Stripping Replacement
Rear deck rattle fix for early cars (tennis ball mod)
Replacing E46 Sideview Mirror Glass
Cheap Rear Quarter Panel Window Stripping Replacement
Rear Vent Window Bolt Retrieval From B Pillar
Replace Individual LEDs in Tail Lights
Side Finisher Rubber Replacement and Rear Side Window Trim Replacement
CSL Console - routing the side mirror control
CSL Roof install
CSL Front Door Airbag Delete
CSL Airbox and Air Duct install Guide
CSL interior swap (comprehensive)
Replace Electrochromic (Auto-Dimming) Mirror Glass
Coding/Tuning
Engine
Rod bearings
Header install
S54 Vanos info
Transmission
CPV valve
Differential
Fluid Swap
Steering
Suspension
Suspension setup
Flex Disc (Guibo)
Subframe Plates
Brakes
Stereo/ICE
Stereo Wiring Guide
Other
CSL Roof install
