Originally posted by heinzboehmer
DIYs
2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
Originally posted by duracellttu View PostI'm looking for a oil filter housing gasket DIY. Anybody know of a good one? I've been reading the one by Pelican Parts, which is a good start.
Specifically, I want to know if it's necessary to drain the oil. Trying to avoid that if at all possible.
Also saw this post on torquing the housing.
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
Highly recommend the Bavarian Autosport Viton OFHG. I do believe ECS carries it now.
Excellent point on the torque method. I’ll hand tighten top 4 evenly, then do a Star pattern torque on the top 4 , and finish with the bottom 2.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
Originally posted by cobra View PostVANOS bolts replacement and oil pump disk replacement
https://www.youtube.com/watch?v=9SkT2j3jsU02002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Just fyi, looks like they did the timing incorrectly. You're supposed to torque the hub bolts with the VANOS fully seated against the head, not with it off. Follow TIS or the Beisan procedure and you'll be good.
If you put it back together the same way you took it off it's perfectly fine. If you're swapping parts and don't have a reference then the Beisan way is the way to go for sure.
S54 Vanos Info Thread
http://uploads.tapatalk-cdn.com/20170709/b427cc1ecdc0899673ce51539b3394e1.jpg http://web.archive.org/web/20180214064458im_/http://uploads.tapatalk-cdn.com/20170709/a40017b090c94ffa891574d94069c3c0.jpg Disclaimer: ( Most of the M3Forum links below do not work anymore ) Please read and completely understand the timingTTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Is it just me or does the link for every DIY from “Replacing e46 side view mirror glass” down take you to this specific post??
(Note that this is only in Tapatalk, so I suspect it’s something weird for just me, but pretty odd)
Last edited by karter16; 02-20-2022, 10:33 PM.2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats
As suggested by Casa de Mesa
My guide how to order genuine special tools based on the numbers in TIS.
Hello everyone, Occasionally I order some genuine BMW special tools as described in TIS. I find them to be of far better quality than some aftermarket replicas available, and it makes for easy repairs. At times, I have had issues finding the right part number to order the tools, since BMW decided to obfuscate this with theirE46 ///M3 • 12/2002 • phönix-gelb • 6MT
BMW S54 WPC Treated Rod Bearing Kit Installation Instructions.
http://bd8ba3c866c8cbc330ab-7b26c6f3...n_-_Turner.pdf
Originally posted by karter16 View PostIs it just me or does the link for every DIY from “Replacing e46 side view mirror glass” down take you to this specific post? (Note that this is only in Tapatalk, so I suspect it’s something weird for just me, but pretty odd)
Last edited by WOLFN8TR; 07-09-2022, 01:44 PM.TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Great info in here!2005 E46 ///M3 Interlagos Blue
BBS - Recaro - JRZ - PFC - Dixis Spirit - Supersprint - Haimus - Vorshlag - RKP - YFCM - Ground Control - DMG Autosport - Diffsonline - Autosolutions - Koyo - Mile End Composites - GC
