CSL Airbox MAP sensor wiring inquiry
    Updated the post with a diagram. Hope this helps others that find this thread.
    Nice one! Looks great!
      Is 18 gauge wire satisfactory for constructing this harness?
      Old, not obsolete.
        More than enough.
        Try to use TXL instead of GXL or SXL.
          Originally posted by Bebop View Post
          More than enough.
          Thanks.
          I have enough 18g TXL left from my electric fan project to get this done.
          Mostly I was concerned with it being sized correctly for the OE connectors. A little googling indicates the connectors accommodate wire with a cross section of between 0.5mm and 1.0 mm. 18g falls right in there. I was just too lazy to look for myself and figured the hive mind would know.
          Old, not obsolete.
            Complete derail, but you wired a fan with 18AWG? Bit small ain't it?
              Fair question. The 18g was for the fan controller. For the fan itself I used 10g.
              Old, not obsolete.
                I sent a note to the folks at: https://auto3design.co.uk/online-sho...onversion-kits
                They noted the following:
                Reach out to them if there's interest.
                FYI, I contacted Auto3Design recently as well and they are going to build and sell a harness based on the diagram in this thread. I asked them to size it for an air rail mounted MAP sensor. The link should be available this weekend, and the harnesses should be ready next week. Will be interested to see how it looks. . . . I'll likely give it a try as I gather parts for an airbox install.
                  Hey turns out my illustration was good for something! glad to see this move forward. Post up when you have it so I can see how they handle the fit and finish.
                  🔹 2001 M3 Laguna Seca Blue
                  Instagram: link
                  Build thread: link
                    Will do! And great work again to you and karter figuring this out. I told them I bet they’ll sell a lot of these because this seems like the new go-to solution for a CSL airbox install with MAP.
                      Discover a wide range of products at our online shop. Enjoy a seamless shopping experience with a user-friendly shopping cart.
                      Looks like a pretty slick solution. You can select your airbox type and if you are using the OEM air rail, in which case they will size the harness accordingly for a clean install. And you can opt to exclude the sensors if you already have them. I'll give it a try and post some pics.
                        much appreciate bavarian3​ for coming up with this. I will definitly run this for my new karb box. I just want to get clarification on v2 connection for MAP signal wire to DME - Do I plug the connector straight into the DME?
                          To clarify this was all karter16 I just helped visualize and surface the information. Check the Diagram again, MAP signal goes into the MAF connection, so the harness above would plug into where the MAF is plugged into on a factory non-csl configuration. Only change at the DME is moving a pin from one slot to another.
                          Instagram: link
                          Build thread: link
                            thank you both!
                              Can someone confirm wiring for the MAP sensor to harness? I am seeing a DME fault for the MAP sensor so want to make sure I haven't got this wrong
                              looking at top of MAP sensor pin 1 right to left pin 3
                              Pin 1 → Pin 7 (5V)
                              Pin 2 → Pin 17 (Sensor Ground)
                              Pin 3 → Pin 18 (MAP Signal)​
                                Pin 1 → Pin 7 (5V)
                                That is the information I have.
                                Are you not wiring it via the MAF connector?
                                Old, not obsolete.
