This is a sticky topic.
    Yeah I was super surprised when I re-torqued my hangers and it actually made a difference. The stock hangers are built with various layers of metal and rubber, so I guess overtorquing them thins out the rubber layers and causes more vibrations (and thus drone) to be transmitted to the chassis. The RE hangers seem to be of an all metal construction at the point where they meet the chassis, so that might not actually make a difference in your case. Still won't hurt to use a torque wrench.
    Yes, torque spec for stock hangers is 22 Nm/16.2 ft-lb.
    For what it's worth, just reached out to RE and they recommended that 25 ft-lb is sufficient for their hangers.
    2012 E92 M3 Competition - LeMans Blue / Speed Cloth - 6MT
    [SOLD] 2004 E46 M3 Coupe - Carbon Black / Black - 6MT
      I'm embarrassed to admit I've never bought brand new wheels before, so this is a first for me. Have a square set of Style 260M's brand new from BMW sitting in my garage and a set of Michelin PS4S's on order. Do I need to order new valve stems for said wheels/tyres? FCP sell them and these were the part numbers I pulled from realoem:
      Are these required to purchase or does whatever tyre mounting shop I go to chuck these on at the time?
        Price check on this Imola interior? $2k seems ridiculous for an interior that isn't in mint condition 9/10+. $1200 seems fair?
        Log into Facebook to start sharing and connecting with your friends, family, and people you know.
          Prices on desirable parts (and "well" spec'd cars) has ballooned. Don't try to make sense of it.
            Strongly considering the Turner CSL box kit for my 2002 car. Other than the conversion from MSS54 to MSS54HP and the MAP sensor (either Kassel or from the forum here), will I need anything else?
              https://www.facebook.com/marketplace...2200951884935/
              I don't know who that guy is kidding calling that 7/10. That driver's seat is like a 4/10.
              2002 M3 Coupe 6MT
                One of my friends pointed out that this is just seats, not even the door cards. I got so excited I didn't even notice lol.
                  A silly question, probably, but do suspension reinforcement plates (the ones that go on/under the strut towers) actually improve durability, as opposed to just transferring loads from one area to the other?
                    Not sure if this is a dumb question, but I recently found some subframe cracks on my low mileage’03 (29k miles). I will not be able to have the subframe reinforcement done until the fall or next year. Should I not drive my car until the repair is done?
                      Can I fit 4 OEM 18"s (tires on) on the rear bench?
                        I'd drive it no problem
                          Not sure about the bench, but I’ve fit four wheels with everything folded down.
                            I paid nearly that much for my mint 9/10 imola interior. 1200 is better.
                              A couple of noob questions related to CSL airbox install:
                              (1) can you remove the driver’s side fan shroud without spilling coolant all over or damaging the coolant pipes or is it better to just cut the plastic fan shroud without messing with the pipes (leaning towards this option)?
                              (2) regarding the oil dipstick, does it actually require bending or will simply removing it and rotating create enough space for the airbox?
                                Cut the shroud if you don't want to disconnect the coolant hose, I had to bend my dipstick but I have seen some have simply rotated it.
                                You can reach way in under the driver's side wheel and loosen the bolt holding the dipstick in place to make rotational adjustments.
