Originally posted by Cubieman
View Post
This is a sticky topic.
I'm getting close to pulling the trigger on a Karbonius CSL Airbox, although I have questions regarding the installation/tuning process for these (understood it's involved):
1. What tune options are available these days and which people recommend & why? A lot of posts on this are getting fairly old and i'm unsure which routes are still relevant today.
2. What does the process look like for applying new tunes if I choose to go with someone who isn't local to me?
3. Still trying to determine whether to go with the carbon fiber snorkel vs the OEM CSL flap, leaning towards the flap in order to preserve relatively more day-to-day drivability (if my understanding is correct). Any strong opinions one way or the other here?
4. Anything you learned the hard way during the installation/tuning process that you wish you had known going into it?2012 E92 M3 Competition - LeMans Blue / Speed Cloth - 6MT
[SOLD] 2004 E46 M3 Coupe - Carbon Black / Black - 6MT
Some tips I put in your quote in bold.Originally posted by keljos View PostI'm getting close to pulling the trigger on a Karbonius CSL Airbox, although I have questions regarding the installation/tuning process for these (understood it's involved):
You can simply start with the stock CSL tune and modify it for US cams, easier that it sounds. I simply went to Kassel and bought a spare DME with CSL tune pre-loaded as I was not comfortable doing that back when I installed my airbox. They also installed the H-bridge with is necessary if you want to run the flap.
CSL software available here:
http://www.msstuning.com/mssflasher.html
You reach out to a tuner like HTE or Paul Claude and they send you a tune and you use a program like "BMW Flash" and a USB Cable to flash your DME. If you want a better tune tailored to your car you go to a dyno and have the tuner do a remote tune via TeamViewer on a laptop.
Here is some basic info on flashing your DME:
http://www.ecuworx.co.uk/how-to/usin...fication-tool/
I went without the flap for a while and was glad I got around to installing it, it improved low RPM throttle response and low speed drivability for me. It wasn't night and day, but it made a difference for me. Also, using a program you can choose at what RPM the flap opens in each gear should you ever want more noise. If you do the flap just get ready to run 5 more wires to the DME harness.
Don't overthink it! Also be careful bending your dipstick tube, I went too far and kinked mine a but. Reach in under the the wheel, unbolt from oil pan and simply try rotating it first before you bend it. Clean your idle control valve and throttle bodies while in there. And enjoy!2004 Silbergrau Metallic 6MT
I know there are many threads in which this info can be found but could someone post a quick and dirty list of what parts to drop in what order if I want to drop the entire rear end/racp for a topside job?
Also if anyone has dropped the rear end/racp as one using 4 post lift any tips would be great as I could see the lift getting in the way of pulling the whole thing out from under the vehicle.2004 Silbergrau Metallic 6MT
Here's a concise write-up by turner http://bd8ba3c866c8cbc330ab-7b26c6f3...stallation.pdfOriginally posted by keljos View PostI'm getting close to pulling the trigger on a Karbonius CSL Airbox, although I have questions regarding the installation/tuning process for these (understood it's involved):
The same principles apply. If you are going map based alpha N you will need to adapt/new csl air rail and map sensor plus connection.
Also keep in mind the wait time for karbonius, might be better to order now as opposed to pulling the trigger when you're ready only to have to wait 8-10 weeks or whatever it is.
- Undo handbrake cables inside car (since you start off clean)Originally posted by Cubieman View PostI know there are many threads in which this info can be found but could someone post a quick and dirty list of what parts to drop in what order if I want to drop the entire rear end/racp for a topside job?
- Remove rear v brace
- Remove sections 1-3 of exhaust - Remove heatshields
- Remove all plastic panels
- Remove driveshaft
- Unbolt RTAB brackets from chassis
- Unbolt rear shocks
- Do something about rear brake calipers (either unbolt some stuff and snake them through the gap between the lca and half shaft or disconnect the brake lines entirely)
- Disconnect all electrical wires (I think there's only the headlight leveling sensor, wheel speed sensors and brake pad wear sensor)
- Pull handbrake cables all the way through so that they're free
- Support subframe somehow
- Undo all 8 subframe bolts/nuts
- Lower assembly sloooowly
- Check everything periodically as you lower it to make sure you didn't miss unbolting something
I might have missed something, but that's all I can remember that you need to do.
Can't comment on the four post, but I've removed the entire assembly twice on jack stands. I just set it down onto moving dollies and wheeled it out from underneath the car.
Nice, thanks!Originally posted by heinzboehmer View Post
- Remove driveshaft
Can't comment on the four post, but I've removed the entire assembly twice on jack stands. I just set it down onto moving dollies and wheeled it out from underneath the car.2004 Silbergrau Metallic 6MT
This is incredibly helpful, thank you! A few follow ups:Originally posted by Cubieman View Post
1. How close does stock CSL tune + H-Bridge get the car to an optimal state? Is that meant to be the baseline just to get the car running, with further refinement from a tuner generally required (ex. via HTE/Paul Claude)?
2. Does the tune or the airbox you choose dictate the wiring/sensor setup (or both)? Some tunes/airboxes delete MAP while other setups retain them?
3. Any documentation you've come across for the setup of the flat?
Hope this helps.Originally posted by keljos View Post
CSL gets it close but further refinement (tuning) is worthwhile.
If you use the CSL tune you must wire a MAP sensor, if you don't use the CSL tune you must run an Alpha-N tune (MAP-less). MAP sensor tunes are generally considered better in terms of driveability but some could argue that point.
Well here is my DIY attempt at converting my wiring to OEM CSL after replacing my MSS54 with a Terra Modified MSS54HP. I have an OEM CSL Airbox with Flap and all OEM ducting etc.. Starting to untangle the mess LOL..... http://i17.photobucket.com/albums/b96/ejazsharif/DARTH%20VADER/CSL%20MAP-IAT-FLAP%20wiring/IMG_0840.jpg
I know I have already asked this in other threads and you guys probably rolling your eyes, but I just am not 100% that I've got this figured out. I am trying wire a MAP sensor via a connector made by Kassel. I have called Kassel and their response is "the wiring is factory CSL". Well I do not have a factory CSL2004 Silbergrau Metallic 6MT
I owe you on this one! You even interpreted through the typo in my last question lol. Much reading to be done, easily accomplished during the 8 week lead timeOriginally posted by Cubieman View Post
Hope this helps.
The bolt pattern fits, but Camaro wheels have a 67.1mm center bore. In theory, you could have a machine shop open this up to 72.6mm which is what an E46 takes.Originally posted by erickhoyos View PostThis is a dumb one, will Camaro/Corvette wheels fit on an E46 M3? Both have the same 5x120 bolt pattern but my guess is no
This is more difficult than going the other way, because you can just use a hub centering ring to compensate for an overlarge wheel bore.'03.5 M3 SMG Coupe - Jet Black / Black
What about the IAT sensor? What wiring do you need for that? I see the Kassel one available (https://www.kasselperformance.com/pr...or-iat-flange/), but I'm not entirely sure the purpose it serves.Originally posted by Cubieman View Post
Hope this helps.
If you are running CSL or Alpha- N software I would run this harness, they (Turner) also offer a harness that retains the MAF sensor connection. With CSL software (or Alpha-N) you will not need the MAF sensor but you can use the empty connection to your advantage and tap into it to eliminate the need to tap into your DME harness wires.Originally posted by S3diment View Post
Put simply, to make it easy just use this:
