    I dont want to give away core4's documentation freely but 100ftlbs, even on thread in studs, is fine. +1 if you put antisieze on the conical seat of the lug nuts
      My replacement side marker turn signals (Magnetti Marelli) are now showing evidence of moisture intrusion, something my original parts never did but I replaced the originals due to yellowing of the lenses a few years back. And, I need to replace the front corner turn signal assemblies due to yellowing. I"m tempted to forgo the Magnetti brand, and go straight Genuine and just pay the price but curious what others have done here. Genuine, or Magnetti? My original front corner lamps say "BOSCH" and my original side flashers don't say who made them, as far as I can tell. I don't want to buy stuff twice, and it looks like that's the case with these side turns.
        welp, the AC went out during my weekly drive. Had AC for the first 20 minutes and it quit half way through.
        I've checked the AC fuses (28, 62, 63) and they're good. AC clutch engages and stays engaged until I turn off the AC button.
        Any thing else I should look at?
        2007 GX470
        build/journal
        ig: @zzyzx85
          It looks like all the new ones, genuine or Magnetti, are made by AL Automotive and made in Czech Republic. You can try to run a bead of sealant around the backside where the lens meets the body of the corner light. That's usually where the water gets in. It would be a shame to throw those out since they are brand new.
            Good idea, I can try that. So, I assume you would suggest just go Magnetti on the corners, since it seems they may be making the Genuine parts now?
              On ECS's site, you can see pictures for both and the identification stickers are the same, just one with the BMW logo and one without.
                This is going to sound dumb but have you checked that you actually have refrigerant in the system? It sounds like it's running, it's just not cooling
                  Clutch won't engage if there's no pressure in system. If all the gas has leaked it won't engage.
                    Quick sanity check: From what I can tell (visually), the Left/Right inner tie rods are the same; only the outers are different (LH/RH). Am I correct?
                      Correct
                        What is the purpose of this ring on the rear shocks of the Ohlins Road and Track?
                        I'm trying to figure out a clunk on bumps - a mechanic seems to have messed with this ring and I'm questioning if the origin of the problem could have anything to do with it.
                        Click image for larger version  Name:	1045107_x800-167218094.jpg Views:	0 Size:	50.9 KB ID:	277466
                        All I can find in the Ohlins manual is that it's a lock ring to adjust the length, but there isn't much being said about it and how to use it properly:
                        Click image for larger version  Name:	image.png Views:	0 Size:	27.6 KB ID:	277468​​Click image for larger version
                          That ring allows you to unlock the lower portion (gold) and adjust the length of the damper.
                          For the Ohlins, make sure the orientation of the rear spring has the lettering facing out of the wheel well.
                            Ok! The mechanic I brought it to extended it well beyond (about 2cm) the caution mark. I suspect this is the cause of the noise. I found from the Ohlins manual that "The bracket shall not be adjusted below the caution line as it may come loose or break." I am currently thinking about what that means. Is "the bracket" the golden thing? So if mine were loose or broken it would be obvious? Or should I suspect something internal is broken?
                              I'm chasing down a "pulls to the right issue". I had an alignment done last year, it's not the slant of the road, and I just changed my FCABs (not the entire control arm -- yet). I still have the issue, especially under harder braking. So next up on the suspect list is a sticky caliper. The right front wheel seems a lot hotter and smellier after short rides. I just changed the rotors and pads like 50-100 miles ago. I got the fcpeuro kit of zimmerman rotors and Textra OE pads and did all four corners. I'm picking up the rebuilt (and powder coated!) calipers this week and in prep I got the car in the air and took everything apart. Does this brake pad wear look normal? Like I said, probably only 50-100 miles on these pads, so not sure if they still need to break in or whatever - but it seemed odd to me and this is the first brake job on my m3. Looks like some of the ends are "chewed up". Attached are pictures of all four corners. Is this normal? Thanks!
Name:	Screenshot 2024-09-02 3.19.02 PM.png
ID:	277504 Click image for larger version
Name:	Screenshot 2024-09-02 3.19.05 PM.png
ID:	277505 Click image for larger version
Name:	Screenshot 2024-09-02 3.18.54 PM.png
ID:	277506 Click image for larger version
Name:	Screenshot 2024-09-02 3.19.09 PM.png
                                Yep, def. sounds like a stuck caliper.
                                AFAIK, break-in is about pad material getting onto the rotor, not the pad material itself breaking in.
                                The pics on the right are from the suspect caliper, right? They look a bit glazed. Could just be the lighting.
                                2008 E90 M3 6MT
                                2011 E90 328i 6MT
                                RWD, slicktop, no iDrive
