Originally posted by ejendow
$200!!! I replaced that along with the reservoir and feed hose for $250 in 2022! Wow. I'd consider running the URO, or call up a KOI parts house and see if you can have something fabricated. Surely another acceptable option exists. If I recall the hose material type is printed on the hose so that could be a starting point. The only thing you might run into is that, BMW click clamps may not fit. In that case, use a quality (ABA, or what FCP sells) worm drive clamp and it should be fine.Last edited by PSUEng; 03-22-2026, 04:12 AM.
Cleared the first error, but the second still persists.Originally posted by davidinnyc View PostSome new error codes yesterday. I hardly use the AC (drive with the windows down), but yesterday was especially hot and when I took one of the cars to pick up the kids from school in 95* temperatures, I tried to turn the AC on. Snowflake would illuminate and turn off immediately, and the air speed would be limited to 50%. Ambient air temperature reached 110*.
Plugged in the laptop and got these two codes:
24 Additional heater relay
Error frequency: 10
short circuit to batt+
Errorcode: 18010A2445C088510386
255 Energy saving mode active
Error frequency: 1
short circuit to ground
error present
Errorcode: FF42012489CF88510375
Anyone with a similar experience?
David
To the subframe. Part number 8 in the diagram below is the bushing the bolt goes through.Originally posted by xansabi View PostWhat is the diff's front mounting bolt attached to?
Last edited by oceansize; 03-25-2026, 05:24 AM.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Wow, thank you!Originally posted by oceansize View Post
To the subframe. Part number 8 in the diagram below is the busing the bolt goes through.
https://www.realoem.com/bmw/enUS/sho...diagId=33_1076'05 ///M3 Mysticblau Metallic / Grey Nappa 6MT
'24 Audi RS5 Nardo Grey / Black
The triangular exhaust manifold gaskets are now $40 each. No substitutes or is Elring ok in this instance? Seems in the past they were not ok.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
I have only ever used elring for the Sec. 1>2, never any issues. Have reused them once before as well and no leaks.Originally posted by oceansize View PostThe triangular exhaust manifold gaskets are now $40 each. No substitutes or is Elring ok in this instance? Seems in the past they were not ok.
BMW gets those from Elring, so Elring is good for this part. Headgasket and VANOS gasket are also made by Elring.Originally posted by oceansize View PostThe triangular exhaust manifold gaskets are now $40 each. No substitutes or is Elring ok in this instance? Seems in the past they were not ok.
Thank goodness, I don't mind spending money on my cars, but 40 bucks on tiny metal gaskets is crazy.Originally posted by Slideways View Post
Is there a database of vehicle height depending on which shocks / springs combo is installed?
I've got some B6 / H&R on mine and the ride is awful, especially the front end. I live in TN, drive on backroads with less than stellar pavement etc and I don't want to deal with that.
I am trying to go back to a higher / more compliant setup and am wondering which direction to head towards.
After reading a whole bunch, I think the Dinan springs are what is the most recommended.
I also read the B6s are lifting the car over stock.
The current setup is about 13" in front, 13.25" in the rear. The rear is good and feels decent, so maybe I'm wondering about just swapping the front springs.
Has anyone tried that?
H&R did not make a good set of springs for this car. They give way too much of a drop up front without a comensurate amount of spring rate increase. The rear is pretty good. Then combine that with the harsh B6s (that need travel) adn you've got a bad combo. They switched up the b12 kit to go with Eibach springs later, which are much better.Originally posted by Bebop View PostIs there a database of vehicle height depending on which shocks / springs combo is installed?
Despite the harshness of bilstein, I still think b6s are better than koni yellows. Just need to get a set of Eibach or Dinan springs if you wish to keep that stock style of shock/spring combo. Or look at coilovers. I would suggest nothing cheaper than pss10 or kwv2s. Camber plates (GC or TMS street) would also give the b6 struts more travel up front which would improve things.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Thanks for the reply.Originally posted by Tbonem3 View Post
I have some GC street camber plates already installed. Probably should have mentioned that.
Unfortunately, coilovers aren't in the budget at the moment.
Mainly wondering if I should go with Eibach or Dinan...
Eibach might be a little cheaper or easier to find. Prob be able to get a used set from someone here for cheaper.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I recently refreshed my suspension with Bilstein B6s and Eibach springs and the combination is working well for me; the ride firm but not harsh in any way, and this is on pothole plagued LA roads.Originally posted by Bebop View Post
Mainly wondering if I should go with Eibach or Dinan...2002 TiAg/M-Texture
