    thermostat, o-rings and coolant...sounds crazy high
    That’s what I had thought.
      What brand for oil level and temp sensor since hella doesn't seem to be in circulation anymore? Has anyone tried newer gen bmw sensors?
        You just moved to CSL firmware, right?
        Both the physical CSL dipstick and the CSL FW call for more oil. If you started getting that light recently, it might be because of that and not a failing sensor.
        You can add more oil or mess with the tune:
        - https://nam3forum.com/forums/forum/s...6059#post46059
        - https://nam3forum.com/forums/forum/s...271#post260271
          I've been quietly thinking how odd it was that it started happening right as I did my intake! I'm like 5/6 to the max line. I assume it's supposed to come up when low? I'll add more oil since the CSL dipstick shows the engine is okay for it.
          I have shifter parts for you to scan btw.
            Is there any quick and dirty way to fix a sagging headliner (other than using pins) without removing the headliner?
            Eventually I will replace the windshield and do it right.
            The area is near the driver C pillar, wondered if I could remove the pillar and use steam to maybe reactivate to glue or get some adhesive up in that area.
            Thanks for any ideas/tips.
              I assume BMW specced more oil on the CSL for the increased heat capacity.
              Hell yeah! Let's do that sometime soon.
                For those of us running the OE non-CSL dipstick with CSL software, where would “full” be? I’ve randomly received the yellow light over the years. Never realized this could be the issue.
                Mike
                02 M3 Titanium Silver / Black
                11 Tundra SuperWhite / Black
                  Mike
                  The FW has it 4mm higher, so CSL full would be 4mm above the max fill line on the non-CSL dipstick.
                  This corroborates the difference: https://nam3forum.com/forums/forum/s...7267#post97267
                    Awesome. Learned something new today.
                    Mike
                      Struggling to find part number for the plugs that fill these holes on each side of the trunk lid…anyone have it?
                        Maybe this:
                          My Innovate LC-2 wideband arrives Monday. I have euro headers and euro section 1 with cats.
                          It looks as though this doesn't simply replace a pre cat O2 sensor and that I will need to weld in a new bung. Is that correct? I'm also assuming this needs to go pre cat and that a pre cat section 1 install is fine.
                            Yeah, with the euro headers you will need a new bung pre-cat.
                            Most all the aftermarket headers have 4 bungs so all your sensors have a place, it's easier to install one of these in that case.
                              Make sure your shop knows how to weld correctly. Lost a good set of euro headers due to bad welding about 15 years ago.
                              Mike
                                I bought a Dinan intake kit and studying install, my laziness is really kicking in. Supposed to relocate the Xenon ignitor per Dinan instructions and I'm thinking, really? Can anyone chime in on the need for this? My OCD then kicks in with modifying the bracket and I'm like, well, gotta buy a new one of those to keep everything original...man I'm lazy these days. BUT--pulling the driver headlight to do this motivates me to pull the passenger side, and send out to Lightwerkz for the projector rebuild I've been delaying. So not all bad!
