Originally posted by fattycharged
You just moved to CSL firmware, right?Originally posted by YoitsTmac View PostWhat brand for oil level and temp sensor since hella doesn't seem to be in circulation anymore? Has anyone tried newer gen bmw sensors?
Both the physical CSL dipstick and the CSL FW call for more oil. If you started getting that light recently, it might be because of that and not a failing sensor.
You can add more oil or mess with the tune:
- https://nam3forum.com/forums/forum/s...6059#post46059
- https://nam3forum.com/forums/forum/s...271#post2602712002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I've been quietly thinking how odd it was that it started happening right as I did my intake! I'm like 5/6 to the max line. I assume it's supposed to come up when low? I'll add more oil since the CSL dipstick shows the engine is okay for it.Originally posted by heinzboehmer View Post
I have shifter parts for you to scan btw.
Is there any quick and dirty way to fix a sagging headliner (other than using pins) without removing the headliner?
Eventually I will replace the windshield and do it right.
The area is near the driver C pillar, wondered if I could remove the pillar and use steam to maybe reactivate to glue or get some adhesive up in that area.
Thanks for any ideas/tips.
I assume BMW specced more oil on the CSL for the increased heat capacity.Originally posted by YoitsTmac View PostI assume it's supposed to come up when low? I'll add more oil since the CSL dipstick shows the engine is okay for it.
Hell yeah! Let's do that sometime soon.Originally posted by YoitsTmac View PostI have shifter parts for you to scan btw.
For those of us running the OE non-CSL dipstick with CSL software, where would “full” be? I’ve randomly received the yellow light over the years. Never realized this could be the issue.Originally posted by heinzboehmer View Post
Mike
02 M3 Titanium Silver / Black
11 Tundra SuperWhite / Black
The FW has it 4mm higher, so CSL full would be 4mm above the max fill line on the non-CSL dipstick.Originally posted by nuc1 View Post
Mike
This corroborates the difference: https://nam3forum.com/forums/forum/s...7267#post972672002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Awesome. Learned something new today.Originally posted by heinzboehmer View Post
Mike02 M3 Titanium Silver / Black
Maybe this:Originally posted by skylinekin View PostStruggling to find part number for the plugs that fill these holes on each side of the trunk lid…anyone have it?
My Innovate LC-2 wideband arrives Monday. I have euro headers and euro section 1 with cats.
It looks as though this doesn't simply replace a pre cat O2 sensor and that I will need to weld in a new bung. Is that correct? I'm also assuming this needs to go pre cat and that a pre cat section 1 install is fine.Last edited by oceansize; 07-18-2026, 09:21 AM.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Yeah, with the euro headers you will need a new bung pre-cat.Originally posted by oceansize View PostMy Innovate LC-2 wideband arrives Monday. I have euro headers and euro section 1 with cats.
Most all the aftermarket headers have 4 bungs so all your sensors have a place, it's easier to install one of these in that case.2004 Silbergrau Metallic 6MT
Make sure your shop knows how to weld correctly. Lost a good set of euro headers due to bad welding about 15 years ago.Originally posted by oceansize View PostMy Innovate LC-2 wideband arrives Monday. I have euro headers and euro section 1 with cats.
