    thermostat, o-rings and coolant...sounds crazy high
    That’s what I had thought.
      What brand for oil level and temp sensor since hella doesn't seem to be in circulation anymore? Has anyone tried newer gen bmw sensors?
        You just moved to CSL firmware, right?
        Both the physical CSL dipstick and the CSL FW call for more oil. If you started getting that light recently, it might be because of that and not a failing sensor.
        You can add more oil or mess with the tune:
        - https://nam3forum.com/forums/forum/s...6059#post46059
        - https://nam3forum.com/forums/forum/s...271#post260271
          I've been quietly thinking how odd it was that it started happening right as I did my intake! I'm like 5/6 to the max line. I assume it's supposed to come up when low? I'll add more oil since the CSL dipstick shows the engine is okay for it.
          I have shifter parts for you to scan btw.
            Is there any quick and dirty way to fix a sagging headliner (other than using pins) without removing the headliner?
            Eventually I will replace the windshield and do it right.
            The area is near the driver C pillar, wondered if I could remove the pillar and use steam to maybe reactivate to glue or get some adhesive up in that area.
            Thanks for any ideas/tips.
              I assume BMW specced more oil on the CSL for the increased heat capacity.
              Hell yeah! Let's do that sometime soon.
                For those of us running the OE non-CSL dipstick with CSL software, where would “full” be? I’ve randomly received the yellow light over the years. Never realized this could be the issue.
                Mike
                02 M3 Titanium Silver / Black
                11 Tundra SuperWhite / Black
