M3 Weight Data Thread
    Weighed the roof 3 times with just the roof and got anywhere from 21.8 to 22.8 lbs. Doing the "weigh yourself only then hold the roof and weigh yourself + roof" method, it was 22.5 lbs. So call it about 6 different times weighing it, the roof alone without the roof bow is 22.5 lbs.
      Wow, that's surprising. Thought it would weigh less. Karb says their roof is 3.3 kg (7.3 lbs), so 15 lbs less just from swapping out the roof panel, not to mention all the other stuff.
        Yep. So that's why I was thinking it's closer to Lang's estimate.
        With the Slon carbon roof bow, gains are even more.
        I have a bunch of parts I took off the car that aren't going back on. I'll x-ref the list you have above, weigh them (in particular if they are missing from your list) and report back.
          Awesome. I actually have a Slon roof bow just sitting around waiting for the eventually carbon roof install. I can weigh it and report back.
          Anyone have an OEM one to weigh it? RealOEM says 1.243 kg (2.74 lbs), but I don't really trust it for weights. Although I can't imagine it will be much heavier than that.
            That sounds like an overestimate, if anything— stock one is pretty freaking light.
              Slon one weighed 443g (0.977 lbs).
              That sounds like an overestimate, if anything— stock now is pretty freaking light.
              Yeah, I would think the stock one is pretty light too. Considering selling the Slon one because I'm not sure 2 lbs is worth the extra money. Think I'd probably need to see someone weigh the stock one before making a decision.
                When I was going back and forth with Slon on PM asking him lots of questions about their roof, the weaves available, etc., here is what he said about hew weight difference of their carbon roof bow:
                "...if I'm correct 1.7kg on steel vs 450g on carbon fiber."
                So if that figure is accurate (which, it looks like his quote on their own part is slightly more than what actual turned out to be) and for all the Imperialists out there, 3.74 pounds vs. 0.99 pounds. Or, a 2.75 lbs weight reduction.
                I have not weighed the steel part (never bought it) but could see it weighing that much. Most of the weight in the roof panel I measured above is from the additional stamped steel bracing on the underside, rather than from the actual roof skin that is welded to that bracing. That said, would love it if someone who had the BMW roof bow not-yet-installed could confirm.
                Regardless, IMHO, worth it! You already have the part, I see no downsides here.
                  That is true. Well fortunately I have some time to decide. Still need to do the MK60 swap before even planning the roof.
                    Some various shock weights...obviously not an exact science here.
                    Stock:
                    Click image for larger version  Name:	IMG_5710.jpg Views:	0 Size:	95.7 KB ID:	276284
                    Click image for larger version  Name:	IMG_5712.jpg Views:	0 Size:	93.1 KB ID:	276283
                    JRZ RS2:
                    Click image for larger version  Name:	IMG_5711.jpg Views:	0 Size:	95.9 KB ID:	276282
                    Click image for larger version  Name:	IMG_5709.jpg Views:	0 Size:	104.7 KB ID:	276285
                    Ohlins:
                    Click image for larger version  Name:	IMG_8618.jpg Views:	0 Size:	53.7 KB ID:	276286
                    Click image for larger version  Name:	IMG_8620.jpg Views:	0 Size:	63.1 KB ID:	276287
                    I should also grab some spring weights while I have them all.
                    Although this info is out there, I also weighed my bare, primered genuine CSL bootlid which came out to right about 25lbs
                    🔹 2001 M3 Laguna Seca Blue
                    Build thread: link
                      ​Ok, I weighed the springs also:
                      Stock front:
                      ​vs Ohlins front:
                      Stock rear:
                      vs Ohlins rear:​
                      Nice to see a big decrease in weight in the rear, although there's also an adjuster added. I suppose I shall weigh that as well and edit this post.
                      The front weight is significant though. Will need to change that.
                      Build thread: link
                        Ashtray Rear: 220 grams
                        Cupholders: 172 grams
                        Coin holder: 129 grams (minus 8 grams for the NZ$1 coin stuck in it) = 121 grams
                        Leather handbrake boot: 88 grams
                        Bluetooth Antenna + bracket: 79 grams
                        Console Upper: 180 grams
                        Arm Rest: 1737 grams
                        Build Thread:
                          Anyone ever weigh tires? I was curious as to manufacturer specs and their accuracy. I just bought continental ecs 02 and grabbed some weights before mounting.
                          Front manufacturer specs:
Name:	Screen Shot 2024-11-18 at 7.17.35 PM.png
                          and the actual weight...25.3lb
                          Rear manufacturer specs:
Name:	Screen Shot 2024-11-18 at 7.17.20 PM.png
                          and the actual weight... 26.2lbs
                          Build thread: link
                            One burnout and it should lose that gram, easy.
                            Continental has 24.2 F and 24.5 R. Manufacturing process isn't perfect, so some minor variation in tire weight is probably expected. Something similar being discussed about bicycle tires - https://www.vitalmtb.com/forums/hub/...ight-deviation
                              interesting insight and good point ! I should have weighed all 4. I'll have to weigh the whole wheel & tires to see the differences.
                              Build thread: link
