    Nice. If you wouldn’t mind reporting back after the install this is part of my winter projects. Curious how much space there is and if an elbow is required.
    I’ll try and report back here when it’s all running!
      What I did today for my '03 vert SMG was to sell it! Garage sale stuff will follow soon. It was a fun and difficult learning experience, but its now time to move along! Thanks to all of you who were so helpful along the way.
      Regards,
      Steve
        I’ve been eyeing Ohlins R&T for a long time. I feel like KW v2 doesn’t do it for me anymore plus I want a change. I bought them from FCP so I don’t have to pay for a rebuild down the road and the lifetime warranty is second to none!
        Click image for larger version  Name:	5C900482-C738-4A17-B758-8C8E92D39B3B.png Views:	152 Size:	189.1 KB ID:	133914
          Swapped shift knobs
          from Condor
          to OEM weighted
            Turner reinforcement plates welded to the under carriage, one hairline crack found after subframe removal.
            2003 has 110k miles.
            Sent from my Pixel 5 using Tapatalk
              VinceBar (Epoxy/Rivet) has gone in along with the gusset cups to tie down the top side reinforcement.
                Today my car received a package from Bulgaria. Something carbon and boxy. I'm told it should make everything aft of the exhaust port null and void. Redundant. We will see if conventional wisdom holds true...
                Click image for larger version  Name:	IMG_6518.jpg Views:	3 Size:	212.3 KB ID:	134536 Click image for larger version  Name:	IMG_6517.jpg Views:	3 Size:	176.8 KB ID:	134537
                Click image for larger version  Name:	IMG_6516.jpg Views:	3 Size:	189.7 KB ID:	134538
                  I started my engine for the first time since rebuilding it. This was my first engine to ever rebuild. I’m very happy to finally have it finished, and even more relieved that everything is running as it should leak free
                    Mayan-Viking what's the reason you went for this over karbonius?
                    Always love seeing a good airbox.
                      The primary reasons are as follows:
                      1. Better perceived quality - All bungs have physical threaded billet aluminum connections with custom made nuts.
                      2. Repositioned IAT sensor.
                      3. More info provided by Haimus than Karb - Dyno #s, etc. Haimus seems to have put a lot of thought into redesigning the original CSL box. Check their website vs Karb's site.
                      4. I don't want to use the flap, the Haimus snorkel is a more elegant (simple) solution for my needs.
                      5. 5 year warranty on finish and structure of the Haimus air box.
                      6. The Karb's lead time was 2.5X that of Haimus when I ordered.
                      7. Terrific customer support throughout the ordering process.
                      8. I'm a sucker for things with serial numbers on them.
                      9. I like a good underdog story. I know they've had had a few issues in the past, but they seem to be putting out a killer product at the moment.
                      The CF quality/weave appears to be top-notch imho. I'm very impressed. I will get better pics posted today once it's properly cleaned up and in the right light.
                      Another forum member who lives near me recently ordered the Karb. We will put the two air boxes side by side when his arrives and we will be happy to share our feedback on the similarities/differences between the two boxes. We also intend to dyno both cars before and after the install, so that will be telling to some extent.
                      Then there's the difference in sound. That's subjective, of course, but we will be happy to provide our thoughts there as well. Hopefully people can learn from our experiences as they make their respective decisions on choice of air box. I'm halfway through bearing break-in and I understand the current lead time on Karb is 8 weeks. So while this shootout might not happen tomorrow, it will happen!
                      Cheers,
                      t
                        Cheers,
                        t
                        Excellent post. Points that I consider in response:
                        1. I'll have to scrutinize mine once I get it out of storage and on the car when the car gets put together.
                        2. I don't buy the whole iat relocation that is popular here. I wouldn't alter the position personally because it's the most accurate reading near the throttle bodies, changing this is deceiving the ecu of the incoming temps.
                        3. I'm not sure I want some small operation redesigning something that an entire r&d team did lots of modeling to produce for the engine they designed. I can see the appeal of that idea though.
                        4. Me either, and I quite enjoy the snorkel aesthetic of the karbonius which doesn't utilize the flap also. I'll have to look at the haimus to note the difference.
                        5. Not a factor for me, if the box is well made it's all that matters to me. If the quality wasn't par then I'd sell and get something else likely never utilizing the warranty.
                        6. I understand this.
                        7. Same as karb.
                        8. Same, except meaningful serials mean more to me so aftermarket pieces don't fall into that category for me. It's a perceived or feigned value proposition.
                        9. Piece appears very well made and I'm actually not a huge karb fan if I'm being completely candid.
                        Looking forward to hear thoughts regarding the two side by side. I do enjoy top level composites fabrication and despise mid or lower tier work. I am considering a third airbox at some point to critique as well but that may change once you update this thread.
                          Love me some good shiny objects!! Beautiful looking piece of kit. Congrats on the purchase and the desired outcome on arrival. Will be fun to stack it up next to the Spanish mouse trap!
                            DropTopKingM3 , What did you not like about the kw v2?
                              As far as daily driving I didn’t find them to be comfortable at all. I drove another members fast with ohlins r&t and fell in love immediately.
                                DropTopKingM3 Same here there is a big difference in feel between the two especially on New York Streets. Ohlins definitely get the win.
