    Coffee and cars, tons of E46 presence ๐Ÿ‘
      Installed a Skyer-Motorsport carbon beauty engine cover and my TMS CSL airbox yesterday. Also changed plugs and coils. Still need to clean up the wiring and stuff. Thanks to Cubieman for answering my questions regarding the MAP wiring. I have a ton of rusty bolts that need replacing, hopefully I can tackle that this week. It never ends.
      2003.5 BMW M3 Carbon Schwarz Metallic/Cinnamon 6 Speed โ€“ HTE Tuning | Kassel CSL DME | AA Headers | AA Section 1 | SS Resonated Section 2 | SS Race Section 3 | TMS V2 CSL Airbox | TMS Street Plates | Ohlinโ€™s R&T Coilovers | Ground Control Front and Rear Sways | Ground Control Adjustable Camber Arms | DMG Autosport Pro46R | FreakyParts BBK Front | Porsche 996 Conversion Rear | CMP Stage 1 + 1.5 Reinforcement Plates | CMP Subframe Bushings | CMP RTABโ€™s | Euro Bumper | SGT CSL Trunk | Dr VANOS
      โ€‹
        Got back the c38-81 (originally in AA kit) from superchargerrebuilds.com after shaft and impeller replaced.
        This unit will serve as backup to the replacement unit from AA.
          Preventative maintenance since I'm at 103,500 miles. Funny that I bought this fuel pump back in 2018 and now in 2022 I thought I had installed it years back but I'm rummaging through my parts bin and I see an unopened box which I open up and there is this pump. Whoops.
          I checked the receipt and I paid $367.27 in May of 2018. Checked ECS and the OEM pump is now $449.96 and $483.99 at FCP.
          Click image for larger version  Name:	IMG_2655.jpg Views:	0 Size:	321.2 KB ID:	172812
            Are you going to lifetime guarantee that one?
              No I bought it from getbmwparts.com as I wasn't using FCP much at that time but by late 2018 early 2019 I was using FCP quite a bit. If you're looking to get the pump it is too late, already disposed of and gone. I didn't even think about offering it to a forum member for cheap but I should have.
                The obvious
                  Prepping for a cooling refresh, ac compressor, and pulleys.
                    It was A big couple of days. I need to start a build thread around these parts.
                    The HG failed between every cylinder in the middle layer. In two cylinders it failed on 2/3 of the layers - block and middle side failures.
                      How many miles on engine? What symptoms were you having before you took it apart?
                        211k. Rough running. Random fuel smells (possibly cat related). Warm starts would stumble.
                        Diagnosed down on compression and leakdown test. The hg failed between all cylinders to some degree. Front three were the worst.
                          I fixed my rattling drivers window and made the doors feel like a brand new car not really sure why I put up with this for so many years but I used the links below.
                          Hey guys. I have a 2001 325Ci and when I drive with the front windows open any amount on a bumpy surface the glass rattles. This really bugged the hell out of me and this weekend I got in there and fixed it. My Haynes Manual told me I could not do this job as it required a specialist and...
                            https://youtu.be/P5r0uHT-CKc
                            I've been eyeing doing the same, appreciate the resource! How many door panel clips did you break? ๐Ÿ˜›
                              None! And I did it in a huge rush at 9pm for no real reason.
                                Nav delete complete, wiring harness, GPS antenna and all.
