    Don't make me cop those fenders.
ID:	175417 Click image for larger version
ID:	175418 Click image for larger version
ID:	175420 dropped one on, fitments is tomorrow
        Finally! The Skinz are here! Wasted no time getting them fit to the car. Final surface prep and epoxy tomorrow.
          This was a nice thread cleanse, thank you for that.
          You should celebrate by having some nicely chilled Russian Standard, preferably accompanied by caviar.
ID:	175476 Click image for larger version
ID:	175477 Click image for larger version
ID:	175478 Finally done after 2 days. Oil diverter valve, motul 300v 20w60, powered steering pump, reservoir, and all lines changed. Karbonius fenders fitted and stripped for ppf. Some holes needed massaged and one tab on either side of the car needed flexed to make them fit properly. Final adjustments will be made after ppf. I'm not pushing the grills or the trim in without taking the fenders off just to be safe. Karbonius trunk also got fitted but needs some work to make the lights fit. Mechanical fan got removed and we didn't have time to fit the spal fan. Next up is ppf
              Great job so far! Looking forward to seeing them epoxied and riveted on 👍
ID:	175547 Click image for larger version  Name:	photo_2022-07-11_15-46-57 (2).jpg Views:	24 Size:	57.4 KB ID:	175548 Click image for larger version  Name:	photo_2022-07-11_15-46-58.jpg Views:	24 Size:	56.7 KB ID:	175549 Click image for larger version  Name:	photo_2022-07-11_15-47-45.jpg Views:	24 Size:	57.2 KB ID:	175550
                Already replaced basically half the car with new parts, might as well on this one
                  Fell pray to some Instagram ads and needed some garage door decor anyways. It’s actually…not that bad?
                    I’ve seen those. What size did you get?
                    2004 Silver Grey - Manual - Slick top - Manual Cloth Seats
                      Just pick up another E46 M3 today, a 2005 Competition package in Mystic Blue with some mods:
                        Beautiful! I really need to get me one too.
                          I got the large one from Petrol Vibes. It’s kind of hard to tell the size because of the carpet picture. It’s 3 feet wide. I can’t even remember what I ordered but it looks like they have more options now in terms of detail. You could probably get a cool CSL rear shot.
                            It is HOT in the Mojave. Spent all day putting my car back together, and only needed two parts store runs for paint and a hose clamp.
                            After gluing a couple weeks ago, I hit the Vince Skinz with 3M seam sealer all around before last weekend. The heat here makes that epoxy cure significantly quicker than when I did the Bar in the winter. Today I primed all the bare metal (2k epoxy) then finished with black 1k enamel. Black wasn’t my first pick but it was available.
                            This is embarrassing, but I have no idea where this 4-wire connector goes. It comes out of the trunk with the ride height sensor harness (already got that plugged in). It has about 2 feet of wire to get it where it needs to go, but I just don’t know where that is. Any help on this would be much appreciated since my Google-fu is lacking.
                              ^ DMTL pump
                              IG: @limited.slip
                              Alpine White E90 M3 6MT
                              Alpine White 1 Series M
                                Replaced AC evaporator and a couple other items while in there
                                IG: @limited.slip
