    Brake flush w/vacuum extractor, seriously makes it so easy, fresh trans fluid, fuel filter and new 5" rear springs so my rear GC weighted jacks can articulate. Click image for larger version
ID:	262916 Click image for larger version
ID:	262917 ​​​​​ Click image for larger version
      Got this delivered yesterday but picked it up from my office today.
        Originally posted by Feffman View Post
        The flywheel bolts aren't coming out anytime soon. 😈
        Feffman Were the bolt heads pre-drilled and have you had problems with flywheel bolts backing out?
          Originally posted by robgill View Post
          My full set of Karbonius carbon fiber trim arrived for the street car build. Looks amazing 😀
          Unfortunately the car is still at the body shop in the New Rochelle quarantine so it's going to be a while before I get it back 😑
          I don't see that trim on their website. hmmmm
          2005 BMW M3 - Interlagos Blue
            Yeah I think they stopped doing the trim. For BRG I recently used https://www.instagram.com/carbonized_bg/ . Very happy with his work
              This was the first time I've ever had flywheel bolts back out. So much for red Loctite. Probably a mistake of not getting threads cleaned properly when installed last time. Had to replace both discs in the Tilton clutch due to oil contamination, Tilton throw out bearing and the guide tube. Shop drilled each bolt in a jig as needed, then wire tired for security.
              Feff
              MVP Track Time
                Coated my ZCP wheels with Armour Detail Supply Wheel Coating:
                2005 BMW M3 (6MT) Instagram
                  Beautiful car and beautiful garage!! Impressive
                    This arrived yesterday!
                    it’s replacing my Megan racing Supremo section 3. Hoping it will clean/quiet everything up.
                      Appreciate the kind words!!
                        Pulled the trigger on an AiM MXG 1.3 Dash
                          These showed up from Team Schirmer today. Less than 4 weeks from ordering
                            Wow! Can’t wait to see those mounted!
                              Feed the addiction…
                                *in a British nature documentary voice *
                                ”Ah, here we see a bmw in its natural element. If you listen carefully, you can almost hear the owner’s wallet crying”
