    Is the spal fan the curved blade fan, or the straight blade fan?
    The curved blade unit.
    It's part number VA18-AP71/LL-59A 12V.
      Originally posted by Altaran View Post
      Swapped the Mishimoto fan with a Spal unit.
      I used the nail mounts that go through the radiator. The Mishimoto worked fine, though I don't need the separate control unit anymore since the Emu black can directly control the fan using the water sensors in the motor which is a lot better than using a probe in the radiator.
      I also fitted fitted switches in the cabin, one of which now manually turns on the fan.
      The Spal also runs quieter (not that it matters on my car, can't hear shit inside anyways since it's pretty much stripped).
      Do you have some more pictures of the interior? And the whole car in fact? That looks awesome
        I definitely need to take more pictures. Right now it's still a sort of work in progress but I will make more when I start driving it again.
        I made an IG for the car (@m346gt), but I have not been good at periodic pic uploads 🤣
          Nice, I checked out your IG, yours is US car brought into Germany? I DM’d you earlier and that’s actually exactly what I’m trying to get some info about lol.
            Nice, I checked out your IG, yours is US car brought into Germany? I DM'd you earlier and that's actually exactly what I'm trying to get some info about lol.
            Oh yeah just noticed that 😅
            You've got mail.
              I started some VANOS work. Mainly I am switching back to the correct diaphragm springs for the S54. I am still debating if I install my VANOS as is or bite the bullet and get the Beisan hub.
              very clean inside
                maupineda As-is. Keep the 400 for another upgrade
                  Got a new shifter knob from FCP Euro. Also saw I could reverse the fuel door spring to fix it not closing as well.
                  Also took the car to a body shop to see what fixing up some of the cosmetic issues would take to fix. Mostly the clearcoat on the right side of the bumper behind the wheel that's peeling.
                  I'm really not looking forward to seeing what the estimate for all the work is going to be. Lolol
                    very clean inside
                    If your hub is not damaged, just get the disc with the correct diameter bore and save the rest.
                    Only need a new hub if the old one is damaged.
                      Why don't we put it in my car so we can finally determine if it's any louder or better sounding than the CF trumpets (that I currently have)
                      I finally put the full carbon race airbox in my car. I'm just going off memory and I don't know if it's just in my head because it was mentioned, but it seems to have a little less bark down low. I haven't had a chance to drive it around on the top end yet.
                        very clean inside
                        Click image for larger version  Name:	IMG_0848.jpg Views:	44 Size:	191.3 KB ID:	272747
                        Click image for larger version  Name:	IMG_0847.jpg Views:	43 Size:	218.4 KB ID:	272748
                        Which car is that? MZ4?
                          According to spal the curved blade fans stall out easily. They recommended straight blade fan VA33-AP71/LL-65A P/12V
                            That is also a curve blade fan.
                            Mike
                            02 M3 Titanium Silver / Black
                            11 Tundra SuperWhite / Black
                              Do you have vanos tests from before? It would be really curious to see what the test shows before and after with the only change being the springs.
                              Email to [email protected]
                                I do not have test from before, just after. All tests passed and pressure tests are in spec (per my sale thread). the only "note" is the reaction time is 290ms, which are a bit high for my liking. I will share the reaction times after the spring change so we will have a before and after.
                                Tolerance on ISTA for reaction time is 500ms!!!
