    Originally posted by ramzM3 View Post
    Well, the weather cooperated and I finally got around to checking out the new fan clutch to see if it made any difference. As you can see, the car said it was 98F outside, the oil temp was good and centered on 210F, the engine temp was up a bit past midway with the A/C running. I had just come to a stop at a stoplight when I grabbed the phone and took this shot. Does that engine temp seem "normal" for a hot day like today? The engine coolant temp gauge did come back down towards the center point after I was moving again. So, I'm thinking that things are better now, when compared to the old fan clutch. Before I installed the new one, the temp gauge went past the right/last white dot, closer to the red zone and it the ambient air temp wasn't as hot as it was today. Your thoughts are appreciated! Thanks!
    check your cluster as well
      Mounted my RS2 steplip 19'' conversion today. Still need to weld lips and barrels together and after send centers for paint/powdercoating
      19x9.5 et31 & 19x10.5 et19​
        Wow those look so classy. Gorgeous!
          flushed my brake fluid and put on my track wheels.
          I think I need to drink more water (or the fluid was due for a change 🤣)
          2007 GX470
          build/journal
          ig: @zzyzx85
            120K miles
            Installed new coolant expansion tank
            swapped out SAP to another one that doesn’t whine
              ​​​​​Had to swing by Harbor Freight and thought I'd grab a few photos.
              I think I'm going to refinish my Volk G.2 in gunmetal whenever I refinish them.
ID:	287154 Click image for larger version
ID:	287155 Click image for larger version
              2007 GX470
              build/journal
              ig: @zzyzx85
                Finally got around to working on the Imola.
                1. Karbonius CSL airbox (plastic trumpets)
                2. CSL air rail with Kassel Performance MAP sensor cable
                3. Turner Motorsport IAT relocation / Alpha-N cable without MAF connection
                4. Kassel Performance MSS54HPCSL DME
                Things I didn’t do but will when I find time again:
                1. CSL dipstick install
                2. Karbonius snorkel + custom snorkel-to-brake duct tube
                3. SMG pump relocation to drug bin
                4. Burkhart Engineering SMG motor replacement
                5. Turner Motorsport triple baffled steering fluid reservoir
                  Track day at Streets of Willow. 1:29.xx isn't flying but it was a nice day at the track. More traffic than I anticipated but I'm still learning the car. I'm not brave enough to drive it without the DSC on "track mode".
                  2007 GX470
                  build/journal
                  ig: @zzyzx85
                    Draped it for surgery. Hoping to pull the roof out tomorrow and put Karb roof in this weekend.
                    997.1 GT3 Carrara White/Black
                    C43 AMG Diamond Silver/Red​
                      New motor is ready to go compliments of ET Tuning (https://ettuning.com/) who did a fantastic assembly and set up job. Special thanks to Peter Partee of Partee Racing (https://parteeracing.com/) who was a sounding board and insight provider. Peter also set me up with the Dailey Engineering dry sump system. Brad Noland of Noland Cylinder Head Service (https://www.facebook.com/nolandscylhead/) and I plotted the path for the head including custom valves from Supertech. Here's hoping it runs like a scalded dog.
                      Feff
                      MVP Track Time
                        Removed trans and bell housing for SMG conversion to 6MT. SMG was in good shape but the other bits within the bell housing where shot. throw out bearing, pivot pin, and fork were all heavily worn.
                          Feff
                          Wow that looks amazing.
                          Belt driven dry sump?
                          Still planning to use the belt driven power steering and alternator?
                            Lots of photos please, I will definitely be picking your brain soon. Let me know about those specialty tools you got, if you want to part with them after I’ll buy them from you.
                              Yes, the Dailey Engineering dry sump is belt driven. Jury is still out on if I retain the belt driven power steering pump. Will decide after new engine is installed. Under hood space is at a premium.
                              Feff
                              MVP Track Time
                                I felt that the information available online for DIY was a bit lacking, so I plan to make a separate thread with advice and photos.
                                Have had some people reach out to me about the tools, so I’ll probably rent them out. We can chat about that if you’re interested.
