    simon_c Yea he cleaned them, above and beyond seller for sure.
    elrichmeister yes, but I believe they were his only used set. New BMW is selling them for something ridiculous around $5K
      Were the euro section 1 cats also acquired through bmwfnatic?
      This may be something i want to acquire soon.
      Shoot me a PM, we’ll figure something out.
        Thanks to bmwfnatic
        New Euro Headers
        Used Cats
        Click image for larger version  Name:	image.jpg Views:	5 Size:	209.9 KB ID:	289930
        That's awesome! He is a great seller.
          Got my M3 running again, been 9 months. Gonna feel good to get the airbox and Dixis singing again. The F80 carbon driveshaft is finally going back in.
          Instagram: @logicalconclusion
            Originally posted by ejendow View Post
            I remember when this trunk was posted on FBM. Keep us posted on how it turns out!
            Finally got around to posting the results. It was a lot of custom work but it was to be expected for a $800 trunk (plus paint, wiring, etc.) Pretty content overall!
            I still wonder about the brand, it was based on a A9? 09/2003 mold for what it's worth.
            Click image for larger version  Name:	IMG_0301.jpg Views:	0 Size:	272.5 KB ID:	290081
            Click image for larger version  Name:	IMG_0313.jpg Views:	0 Size:	175.6 KB ID:	290082
              Wow that turned out great! Would love to see some more photos.
                New Wheels, Tires, MH Studs & Spacers
                  I really would love to get that DS sorted out one day. Im going to start checking around here if there is anyone who can do the balancing work
                    OE CSL engine harness on the way. Cant wait to clean up the wiring in the engine bay even though the way it was done is OE style.
                      Post-track day oil change for the M3.
                      ​​​​I might have picked up something new to play with (at a much later date).
                      Click image for larger version  Name:	20250111_105837.jpg Views:	4 Size:	171.6 KB ID:	290320 Click image for larger version  Name:	20250111_105920.jpg Views:	4 Size:	180.2 KB ID:	290321 Click image for larger version  Name:	20250111_105905.jpg Views:	4 Size:	190.5 KB ID:	290322 Click image for larger version  Name:	20250111_105851.jpg Views:	4 Size:	203.7 KB ID:	290323
                      1989 325i. 1 owner. Auto but that won't matter for what I plan for it (saves the M3 from going full racecah)
                      2007 GX470
                      build/journal
                      ig: @zzyzx85
                        Took the extra time over the holidays to knock out a bunch of small items I had laying around.
                        - Switched out the Redline MTL @ 18k miles for Ravenol 75W-80 MTF-2. Don't remember what Pentosin was like as I haven't had it in the box since before prices skyrocketed, but compared to MTL it's much less crunchy when cold and feels pretty consistent all the way up to operating temperature. Don't expect I'll be changing this stuff for a good while, but time will tell.
                        - Replaced the clutch stop that had disappeared at some point with the anchor bolt solution
                        - Refreshed clutch and brake pedal bushings with AKG, no more lateral slop in either pedal
                        - Bled brakes and clutch
                        - Swapped in the BMW weighted performance knob
                        Combined with recently refreshed shifter linkage parts and the E60 short lever, I'm quite happy with the overall shifting experience now. Diff bushings / rebuild will be the final item in this category sometime in spring, then I should be all done with drivetrain.
                        '04 LSB Coupe 6MT
                          Wow that's quite a feat, have you had to open the engine? with that many miles? my M3 currently sits at 170k, put on about 25k miles during my 3 years of ownership, plan to put more.
                          2004 M3 6MT |Eventuri Intake|
                            Nothing beyond the normal maintenance items like rod bearings and valve adjustment. There is a good amount of varnish and some carbon build up in the head from previous owner doing long OCIs. I really need to do a compression test to see where it's at with so many miles when I do the rod bearings at 300k.
                            2007 GX470
                            build/journal
                            ig: @zzyzx85
                              Click image for larger version  Name:	IMG_1802.jpg Views:	96 Size:	179.6 KB ID:	290599 Saving these for a rainy day fresh from BMW
                                Not much on the M3 as of late but have the SMG3 out the M6 for a LW flywheel, R.M.S, new orings all around on the SMG, new SMG pump motor etc.
ID:	290613 Click image for larger version
ID:	290606 Click image for larger version
ID:	290607 Click image for larger version
ID:	290608 Click image for larger version
ID:	290609 Click image for larger version
ID:	290610 Click image for larger version
ID:	290611 Click image for larger version
