While doing rod bearings and front subframe removed, cleaned everything, put new Lemforder inner/outer tie rods, OEM CSL knuckles, new wheel bearings, new PS lines. Also add 2 shims to power steering pump for 25% assist reduction. Also new rad hoses. List is long, doing complete refresh!7 PhotosSend me a pm for Gt4 Composites carbon fiber CSL parts
- Likes 8
Please forgive my ignorance, but when a clutch fan is deleted isn't a more powerful electric puller fan put in place?Originally posted by davidinnyc View PostDeleted clutch fan, went on a spirited drive in 83 degree weather in an SMG, learned that a clutch fan is very much needed for an SMG.
From my experience the clutch fan works very well. Last year i replaced the fan clutch and my summer time coolant temps cooled down dramatically. The coolant temps used to reach 3/4 in 95+ F temps with AC, now i can run the AC in 100+ F and it stays at 1/2 mark.2004 M3 6MT | Eventuri Intake | 3.91 | Wavetrac
I deleted the fan without an electric fan in its stead.Originally posted by elrichmeister View Post
I have another stubby sitting on a shelf in the garage if you want it.Originally posted by 6speedS54 View PostMy stubby antenna broke and left the bolt inside the base. Replaced base, had a 10mm socket drop into one of the channels below it, it was unbelievable, the socket is 2.5 inches long and it finds a way into a small channel. Picked it out with a magnet. 😂
Stick with a fan clutch if it gets above 100F where you are in CA. We have tried and tested the Electric fan BS here in our 125F max Humidity weather and it doesnt work at all if above air temps is 100f and above.Originally posted by davidinnyc View PostDeleted clutch fan, went on a spirited drive in 83 degree weather in an SMG, learned that a clutch fan is very much needed for an SMG.
I managed to limp on and off the freeway ~20 miles over 2 hours… had to keep pulling off to the side with hazard lights and letting the car cool down just enough to get the SMG cog light to turn off.Originally posted by 0-60motorsports View Post
Needless to say the clutch fan is back in the car and I now have a clutch fan delete cap to give away!
Also for SMG cars (I Love my SMG and would never swap to 6MT unless I had no choice) Do the SMG pump relocation, Thank me later LOL (it works in our extreme weather)Originally posted by davidinnyc View Post
Thanks for posting pictures of this mount installed. I will be placing my order. I appreciate your recommendation!Originally posted by BTB View Post
Yes, it will limit movement of the muffler and should last longer than stock (FWIW I've only been running (1) of these for almost a year). To me it is just a great product overall, you can buy shims if you need to change the position of the muffler relative to diffuser. 1 track day down and no issues for me
(my diffuser fitment has been screwed up for some time, please ignore hah)
EDIT: I just placed my order for one of these exhaust mounts from Rogue Engineering.Last edited by cakM3; 02-27-2025, 04:17 AM.
Same, I have to order one as well. One of my stock mounts is torn, so great timing on the suggestionOriginally posted by cakM3 View Post
Refreshed (clean & regrease) the rear axles. Needed to replace the driver's side inner CV joint as it apparently overheated (nice blue tint) causing pictured damage. To help, I heat-shield wrapped the exhaust pipe which runs directly underneath the driver's side CV joint. Fingers crossed.
Feff
Got a part number for the inner / outer CV joints?Originally posted by Feffman View PostRefreshed (clean & regrease) the rear axles. Needed to replace the driver's side inner CV joint as it apparently overheated (nice blue tint) causing pictured damage. To help, I heat-shield wrapped the exhaust pipe which runs directly underneath the driver's side CV joint. Fingers crossed.
Feff
Mike02 M3 Titanium Silver / Black
11 Tundra SuperWhite / Black
