    Went into limp mode in the first 2 min on the road, plugged the TPS back in after my dumb ass left it unplugged while doing an oil filter change... made it through all the VANOS bulletproofing flawlessly only to do stupid shit like this ๐Ÿ™„
    Yup i did exactly this after vanos as well!
      Make it three, that one has caused more than one โ€œfuuuuuu ...โ€ after a big job (also including a flawless VANOS bulletproof) followed by sweet relief
        Had a busy Saturday with the M3.
        Swung by my friend's house to use his garage to rotate the tires. There's some camber wear up front so hopefully rotating them will even out the wear.
        Later I took apart the CSL intake to clean out the ash and whatever crap has gotten stuck in the air filter since I've installed it. Got to ogle at the carbon fiber masterpiece that Karbonius made. I thought I was going to see more oil blow-by but it looked pretty good in there.
        2007 GX470
        build/journal
        ig: @zzyzx85
          Drove it 900 miles to see family. Lost a fender grill somewhere along the way :/ i brought my laptop and a good amount if tools just in case. This is the first real road trip ive been on with this car because it was formely a SMG. Its been converted about a year and a half now and im feeling some confidence leaving home. Ill post again once shes back at the stable.
            Treat yo self
              Originally posted by Stack View Post
              Treat yo self
              Niiiiiiice
                Finished up major suspension refresh. New struts, new shocks, new FCABs, new RTABS, new RSMs. Added reinforcement plates to the rear wishbones and to the front shock towers. Need to actually replace the rear wishbones but that damn diff is in the way...so the shop can do that before they align the car...along with a few other things like subframe/diff bushings. I did manage to fix the stripped set screw in the rear spring perch, so small personal victory there.
                  Treat yo self
                  Welcome to the nickel plated crew.
                    New Plates
                      Did some interior work.
                      Installed Sparco SPX Seats
                      Cleaned up the trunk. Delete all radio related stuff. Weight was at least 35# for the full HK with NAV and wiring.
                      Installed new door seal trim at $400 per side. Ouch. Also new A and B pillars.
ID:	68131 Received my Stoptech C43 Ultralite kit
                        Last edited by Nihilation; 11-17-2020, 07:05 PM. Reason: https://lh3.googleusercontent.com/yG5wNTZ9O-N8QjUASPC3fg5duhOzrhrHZQc7BNFOvEgrh7Dle3GGVFtV-DpWc3tiqLIlu0jlZcxiMtU6f7i9utysOAwC6cNvVAMcY12yUmyyQekz35oTLGS32T4GyHlJ31-h-BPfyYWsdCkmd_O1Jg5fuhdB4f6i03CiGB
                          Those look great ๐Ÿ‘ hopefully no knock back. What size rotors?
                            332x32
                            Sent from my Pixel 2 XL using Tapatalk
                              New Mats
                                Iโ€™m in the market for a light weight track setup. I was thinking about the AP kit and never noticed the Stoptech light weight setup you have. I canโ€™t find much real world info on them. Those look very interesting.
