Bry5on and heinzboehmer (hope you don't mind me tagging you both!) you've driven each other's cars post this tuning process yeah? Keen to know what differences there are in "drivability" between flap and no-flap setups that are properly tuned? Any thoughts/comments on that?
A quick and easy way to street tune your CSL conversion for drivability.
2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace
Originally posted by karter16 View PostBry5on and heinzboehmer (hope you don't mind me tagging you both!) you've driven each other's cars post this tuning process yeah? Keen to know what differences there are in "drivability" between flap and no-flap setups that are properly tuned? Any thoughts/comments on that?
However, I haven't noticed enough of a difference to make me want to get the flap.
(Also Bryson's car has smaller diameter tires, which, to me, makes a much bigger difference in driveability)2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Originally posted by karter16 View PostBry5on and heinzboehmer (hope you don't mind me tagging you both!) you've driven each other's cars post this tuning process yeah? Keen to know what differences there are in "drivability" between flap and no-flap setups that are properly tuned? Any thoughts/comments on that?‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
Hi !
I'm currently in the process of logging and correcting the VE map. (3rd iteration as of now, slowly getting there)
Can someone confirm (or correct me) that, VE Table is only used during Closed loop ?
I'm doing this process over a WOT corrected tune, so I just want to be sure that during WOT, ECU does not use VE table. (Which would interfere with the current WOT tune)
Thank you for your work guys, this is quite easy to understand and replicate (even for a noob like me)
The WOT table is a multiplier applied over certain cells in the VE table. So changing your VE table can affect your WOT map. The correct way to tune WOT is actually to tune the VE table, but as you state, the car runs open loop in these sections so this method should achieve the same outcome. No, this method will not change your WOT tuning and AFRs.‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
Originally posted by Bry5on View PostThe WOT table is a multiplier applied over certain cells in the VE table. So changing your VE table can affect your WOT map. The correct way to tune WOT is actually to tune the VE table, but as you state, the car runs open loop in these sections so this method should achieve the same outcome. No, this method will not change your WOT tuning and AFRs.
After a quick reading of the tune, full load table was indeed modified, but so was the big Alpha N table. (now richer on bottom end and leaner on top end).
If I get corrections in my VE table using this method, can it "fine tune" the tune I got ?
From my understanding, as my VE table keeps dropping after 3 passes, it means that I was running a bit rich with this tune ?
As far as I can tell, drivability has been GREATLY improved after 3 passes !
Thank you guys.
Originally posted by ac427 View PostSorry for another thicko question.
If TestO is used to log the data and then Excel or MathLab is used view and to manipulate the data.
What purpose does MegaLogViewerHD serve?E46 ///M3 • 12/2002 • phönix-gelb • 6MT
Originally posted by bmwfnatic View PostFiltering the log and compiling the logged data into the required table.
Would https://datazap.me/ do ok or is MLVHD worth the $50 ?
