Originally posted by Mayan-Viking
View Post
Side Finisher Rubber Replacement and Rear Side Window Trim Replacement
Juat received mine and they look pretty great.
Interestingly, even though the eBay listing says they're in Lithuania, the package was shipped from a place not too far from Frankfurt. Gives even more credibility to the claim that they're the actual seals that BMW uses in their parts.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 2
See Post #157Originally posted by Amos View PostSo how do I order, just send an email to that email address? I need shipping to Canada.
Group buy info
Price: $130 USD for one set. $260 USD for two sets. shipped to USA
Send paypal payment to: [email protected]
Under the payment amount it will ask you what this is for and type:
Group buy E46 Rear quarter weather stripping and include your name, full address including USA and phone number.TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
- Likes 3
Just received my set, envelope was way smaller than expected.
Plenty of ‘baconing’ as others have mentioned, but it is what it is.
I picked up a set of high gloss shadowline trim with deteriorated rubber last week, time to combine them and upgrade my car to high gloss.E46 ///M3 • 12/2002 • phönix-gelb • 6MT
- Likes 2
How did you remove the trim piece?Originally posted by Ryan_R View PostThe install isn't horrible. The worst part is probably the small bracket that retains the seal at the rear of the trim piece. You need to remove a rivet that holds the bracket in place. I tried silicone lube and sliding the seal in without removing the bracket but after 15 minutes of fiddling with it I decided to just remove the rivet, install the seal and then rivet the bracket back into place.
Overall the seals feel like OEM quality and the wavy rubber does not show once reinstalled. I do have a bit of gap between the seal and trim but that could be due to my lack of skill or the fact my trim pieces are 20 years old and slightly warped.
I'd like some pointers on the bracket portion--is this a metal rivet, or plastic?Originally posted by Ryan_R View PostThe install isn't horrible. The worst part is probably the small bracket that retains the seal at the rear of the trim piece. You need to remove a rivet that holds the bracket in place. I tried silicone lube and sliding the seal in without removing the bracket but after 15 minutes of fiddling with it I decided to just remove the rivet, install the seal and then rivet the bracket back into place.
Metal rivet. 1/8” diameter. I used a die grinder to get the old one out but I’m sure you could also use a 1/8” drill bit. The fit on the rivet is really tight. I had to get it started and then lightly tap it in.Originally posted by PSUEng View Post
