    Originally posted by Mayan-Viking View Post
    Yeah. I'm out of the window now...
    You can still order. The GB is not time sensitive or limited to a particular number of orders. anyone can order as many as they want.... untill matt tells us otherwise
    2007 Imola Red Z4M Coupe
      Originally posted by AvusBlueAus View Post
      How much was the total delivered to Australia? I’m thinking of getting a set too
      $260 AUD, about $100 less then via his ebay store. and BMW want $2948.5 locally lmao.
      Win of the year.
        I just placed an order over the weekend and emailed to ask for part availability. Got a response from Matt in less than 24 hours, order got shipped today.
          Mine also shipped quickly, have received a tracking number but don't know what company to track with?
            USPS
              Juat received mine and they look pretty great.
              Interestingly, even though the eBay listing says they're in Lithuania, the package was shipped from a place not too far from Frankfurt. Gives even more credibility to the claim that they're the actual seals that BMW uses in their parts.
                Got mine today, also shipped from Frankfurt. Odd that I never got a confirmation or anything at all. But yea they're here. Gonna lay them outside and let the heat/sun straighten them out.
                  So how do I order, just send an email to that email address? I need shipping to Canada
                    Originally posted by Amos View Post
                    So how do I order, just send an email to that email address? I need shipping to Canada.
                    See Post #157
                    Group buy info
                    Price: $130 USD for one set. $260 USD for two sets. shipped to USA
                    Send paypal payment to: [email protected]
                    Under the payment amount it will ask you what this is for and type:
                    Group buy E46 Rear quarter weather stripping and include your name, full address including USA and phone number.
                    Evolve Eventuri
                      Just received my set, envelope was way smaller than expected.
                      Plenty of ‘baconing’ as others have mentioned, but it is what it is.
                      I picked up a set of high gloss shadowline trim with deteriorated rubber last week, time to combine them and upgrade my car to high gloss.
                        Originally posted by Ryan_R View Post
                        The install isn't horrible. The worst part is probably the small bracket that retains the seal at the rear of the trim piece. You need to remove a rivet that holds the bracket in place. I tried silicone lube and sliding the seal in without removing the bracket but after 15 minutes of fiddling with it I decided to just remove the rivet, install the seal and then rivet the bracket back into place.
                        Overall the seals feel like OEM quality and the wavy rubber does not show once reinstalled. I do have a bit of gap between the seal and trim but that could be due to my lack of skill or the fact my trim pieces are 20 years old and slightly warped.
                        How did you remove the trim piece?
                          I'd like some pointers on the bracket portion--is this a metal rivet, or plastic?
                            Trim piece is held on by approximately 10 screws behind the weather seals. You’ll need to remove the rear side windows.
                              Metal rivet. 1/8” diameter. I used a die grinder to get the old one out but I’m sure you could also use a 1/8” drill bit. The fit on the rivet is really tight. I had to get it started and then lightly tap it in.
                                Can’t believe BMW made it that difficult to replace. The E36 seals were super easy to replace smh. Gonna cry when I install these inside my 110° garage in a couple of days. 😭
                                997.1 GT3 Carrara White/Black
                                C43 AMG Diamond Silver/Red​
