    What's this washer thing in the brake master cylinder (MK60)? A kind of one way valve?
    Refreshing the seals and cleaning everything out before installing this (and other MK60 bits) in the car and it caught my eye.
      Regarding the M10 Copper hex nuts securing the stock Section1 to Manifolds, P/N: 18301317898, I want to use them along with the 11621318568 torx bolts for my SS system install (per Ian's recommendation). Not to be cheap, but to mindful of money spent, is there an acceptable interchange to that M10 nut, say maybe 18307530972 or 18301737774? The only thing I can think of preventing this exchange is maybe a difference in thread pitch however I'm unable to confirm pitch on any listings for the nuts or bolt--all I find is "M10". Any ideas are appreciated, thank you!
      EDIT: Brushing up on metric fasteners, ISO standard allows only the size (M10) to be specified and clarifies the assumption is coarse pitch. If a fine pitch is required, it is listed (x1.0, 1.25).
        I’m heaving a rich running condition with my car. The codes that show up at every a few drive cycles are fuel diagnosis cylinders 1-3 and 4-6. What could cause this? I have a new fuel pump, recently changed fuel injectors, fuel filter and fuel pressure regulator. I also installed new O2 sensors during the SS v1 headers (catless) install. Car has the Turner box with the MAP sensor. Rear O2s and the secondary air pump are deleted.
          Specific codes? What are you fuel trim numbers?
            Fuel system diagnosis cylinders 1-3
            Fuel system diagnosis cylinders 4-6
            These are the only two error codes that I constantly get at every 3-4 drive cycle.
              Weird, never heard of those. Do you have the ECUwerx tool? "Martyn's tool"? That'll give you the fuel adjustments/adaptations.
              Do you have the specific code #s, that might help. The codes' descriptions, as you've written them, sound vague.
                Checked with INPA, stuff is in German. Lol
                  INPA code 174: (P0172)
                  Multiplicative mixture adaptation, cyl. 1-3 control limit reached
                  INPA Code175: (P0175)
                  Multiplicative mixture adaptation, cyl. 4-6 control limit reached
                  Link with some good info:
                  Whats up ladies and gents, so after having the P0172 and P0175 codes on my car for more than half a year, after an engine swap, after many other "common" parts swapped, I have found the solution(s)! I have devised a somewhat systematic, cost-effective as well as intelligent way to go about...
                    Intake air leak. Both banks basically needs to be something common to all cylinders. Do a smoke test.
                      I removed the Turner box twice to make sure there aren’t any damaged lines, boots etc.
                        https://www.e46fanatics.com/threads/...utions.919568/
                        They didn’t write anything other than what I suspected. Good thing I buy all my parts from FCP. So I’ll use the their lifetime warranty and replace the fuel filter, fuel pressure regulator and the fuel pump and see what it does.
                          Doubt it's a fuel issue tbh.
                            I'm installing axle carrier plates and weld in vincebar. Here's the dumb question... Why do the rear axle carrier bushings have such a large bolt diameter for the bolts that hold them?
                            Seems it could move around.
                              Edit: Answered my own question
                                Well my pass side window regulator just crapped out. is there a good alternative to the BMW genuine or is best to buy used OEM?
