This is a sticky topic.
    Originally posted by ZapRousdower View Post
    Why can't I PM? Is there a minimum number of posts one must do first?
    10 posts and 30 days apparently.
      Originally posted by bimmerfan08 View Post
      Not E46-related but related to the layout of the forum. Why is there no subforum for the E30 M3 generation? Noticed it for a while just never got around to asking.
      I noticed it, too. But I imagine it'd be a low traffic / low-post subforum since most of the e30m3 people end up posting on s14.net and s14power.com.
        Figured this as well. I assume Ian or one of the other mods would know the exact rationale. Obioban
          We could do it. Had ~0 posts in the old forum e30 section.
            We could do it. Has ~0 posts in the old forum e30 section.
            Do it, IMO
            2008 E90 M3 6MT
            Slicktop, no iDrive | 脰hlins by 3DM Motorsport | Autosolutions
            2011 E90 328i 6MT
            RWD, slicktop, no iDrive
              Lol. Brutal.
              Need to figure out how to attract E30 owners to the forum.
                猬嗭笍 S14.net is well established. I don't think many of those folks will be migrating here.
                Anyone know the stack height of a stock e46 m3 clutch and flywheel? Is it the same as a E36?
                2003.5 SG/Grey
                  high beam/DRL bulbs: replace with OE, Sylvania/Phillips improved halogens, yellow (might be illegal in CA?), or LED?
                  2007 GX470
                  build/journal
                  ig: @zzyzx85
                    Where can I purchase a clutch alignment tool?
                    I can't seem to find one that will work with the self-adjusting clutch. I see some for sale but they are all of the traditional style that would run into the removable plate on the pressure plate.
                    Edit: Found this, but it lists the non-M's as well in the fitment information so just want to be sure.
                      I have one you can borrow if you pay for shipping.
                        Does anyone know the stock underpanel/belly pan weight? Also what's everyone's experience with the stock ones do they crack easily?
                        My car came with a turner which is off the car right now, was pretty surprised by its weight. Thinking to throw a OE one on.
                        馃敼 2001 M3 Laguna Seca Blue
                        Instagram: link
                        Build thread: link
                          It鈥檚 plastic and super light.
                            I think bavarian is talking about the aluminum belly pan. Its not heavy, per se, but it is quite strong. The PO of my car took it on (what I presume to be) an off road adventure that significantly dented the aluminum pan, it did not crack and I was able to hammer the dent out without any ill effects. Its quite rugged.
                              The turner one is aluminum, but I think he's actually referring to the plastic belly pan since that's what the turner piece replaces.
                              I've dealt with the turner one, not a good part imo - super heavy.
                              Stock is best here. Or even a cheap (Uro/hamburg tecknik/et al) plastic replica might be fine as it doesn't have to do much.
                              DD: /// 2011.5 Jerez/bamboo E90 M3 路 DCT 路 Slicktop 路 Instagram
                              /// 2004 Silvergrey M3 路 Coupe 路 6spd 路 Slicktop 路 zero options
                                I just purchased an 03 HPF M3.I cleaned the ICV and throttle bodies and after I was done car started and ran and I shut it off. Next day I came out to the garage and there was a giant pool of oil underneath the car. Any ideas on what caused this?
