Originally posted by ZapRousdower
I noticed it, too. But I imagine it'd be a low traffic / low-post subforum since most of the e30m3 people end up posting on s14.net and s14power.com.Originally posted by bimmerfan08 View PostNot E46-related but related to the layout of the forum. Why is there no subforum for the E30 M3 generation? Noticed it for a while just never got around to asking.
high beam/DRL bulbs: replace with OE, Sylvania/Phillips improved halogens, yellow (might be illegal in CA?), or LED?"your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
Where can I purchase a clutch alignment tool?
I can't seem to find one that will work with the self-adjusting clutch. I see some for sale but they are all of the traditional style that would run into the removable plate on the pressure plate.
Edit: Found this, but it lists the non-M's as well in the fitment information so just want to be sure.
Does anyone know the stock underpanel/belly pan weight? Also what's everyone's experience with the stock ones do they crack easily?
My car came with a turner which is off the car right now, was pretty surprised by its weight. Thinking to throw a OE one on.馃敼 2001 M3 Laguna Seca Blue
Build thread: link
It鈥檚 plastic and super light.3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
I think bavarian is talking about the aluminum belly pan. Its not heavy, per se, but it is quite strong. The PO of my car took it on (what I presume to be) an off road adventure that significantly dented the aluminum pan, it did not crack and I was able to hammer the dent out without any ill effects. Its quite rugged.
The turner one is aluminum, but I think he's actually referring to the plastic belly pan since that's what the turner piece replaces.Originally posted by jayjaya29 View PostI think bavarian is talking about the aluminum belly pan. Its not heavy, per se, but it is quite strong. The PO of my car took it on (what I presume to be) an off road adventure that significantly dented the aluminum pan, it did not crack and I was able to hammer the dent out without any ill effects. Its quite rugged.
I've dealt with the turner one, not a good part imo - super heavy.
Stock is best here. Or even a cheap (Uro/hamburg tecknik/et al) plastic replica might be fine as it doesn't have to do much.DD: /// 2011.5 Jerez/bamboo E90 M3 路 DCT 路 Slicktop 路 Instagram
/// 2004 Silvergrey M3 路 Coupe 路 6spd 路 Slicktop 路 zero options
