This is a sticky topic.
    Thank you, yea I am going to drive them back in, heat them up, and hope they are not rusted haha. I suppose anything is possible but the car is *mostly* rust free. I think the studs were used to hold the plates in place while the epoxy dried. So I feel like the epoxy is what is making my life difficult, and thus, hoping some heat will help.
    Definitely something is off there. Heat should help, and if you can somehow get some PB in there.
    The double nut method wouldn't work on mine, but an adjustable wrench took it right off. FWIW, vincebar gussets include new studs, washers, and tap.
    🔹 2001 M3 Laguna Seca Blue
    Instagram: link
    Build thread: link
      What are you building?
      Might try Peter Partee with Partee Racing.
      My buddy has an S85 block that needs a bit of machining and we are having a hard time finding anyone, Partee and Troy Jeeup are really the only two I have heard of.
        Had to finally drive in the rain couple weeks ago in the M3 and realized my passenger side wiper mount is toast. Which of these wipers is the correct/better one; couldn't find anything besides broken links and blade refills:
          https://www.fcpeuro.com/products/bmw...ch-61610037009
          The top one is the style the car came with and the other is the more modern style.
          Personally prefer the refills as it is less cost and waste, but a little more work.
            Life/Family/Work has gotten in the way so I haven't got to work on her GPS/SMG issue (https://nam3forum.com/forums/forum/m...t-inpa-version).
            I am able to get INPA to switch the SMG to "N" and the last time I started her was 9 months ago during my troubleshooting efforts. Can I start her up this weekend without having to prep anything? So many hearsays out on the interweb that "you gotta pull the plugs and drop some oil, etc, etc.". She's sat on jacks for 9 months and I haven't open anything.
            17 iO1 i3
            16 F22 M235i
            08 E93 M3
            04 E46 M3 Carbon Schwarz - SMG II - Discovery Automotive tuned - AFE Stage 2 - SS Stepped - SS Metallic Cats - Eisenmann X-pipe - SS Race - 4.10 - ACS CF lip - 6000K Heads & Fogs - Tein S
              Itll be fine, fire away.
              Email to [email protected]
                I got a blowtorch so I'm going to take a swing at it tomorrow. I thought about doing the Vince cups but went with a 6-point rear brace instead because I'm tracking the car, the mounts on the front points are basically the same as the Vince cups.
                '01 M3, Imola/black
                  Thx George!
                  17 iO1 i3
                  16 F22 M235i
                  08 E93 M3
                    I'm getting ready to do belts/tensioners and a few other things. Need to rotate the water pump pulley such that I can get the holding tool on a pair of bolts (the pattern is asymmetric). Belts and everything is currently assembled. Is it necessary to turn the crank pulley here? Last time I did this, the tool just fit so I didn't have to rotate anything.
                      Put a 10mm on one of the water pump pulley bolts and you should be able to make it slip on the belt pretty easily.
                        Put the 32mm fan wrench on the nut and you can turn it backwards easily.
                          When you change shocks / struts it recommended to torque the bolts to spec under load. My question is how do you do that when your working on stands in your garage?
                          ///02 E46 M3 6MT CB over Imola, B16 PSS10 (Daily) Apex FL-5
                          ///05 E46 M3 6MT TiAg over Imola, Ohlins R/T, Apex ML-10
                          09 E93 N54 6MT, Sapphire Black over Dove, 313's (R.I.P) ​
                            Jack it up. And to be clear, you're not loading the bolt or anything, just the rubber bushing, so this only applies to joints with rubber.
                              Bolt them up but leave the bolt 1/2 turn loose or so. Lower the car onto the ground, drive forward and back 5' or so and then crawl under and torque.
                                Why can't I PM? Is there a minimum number of posts one must do first?
