Originally posted by Tbonem3
Originally posted by zzyzx85 View Postwelp, the AC went out during my weekly drive. Had AC for the first 20 minutes and it quit half way through.
I've checked the AC fuses (28, 62, 63) and they're good. AC clutch engages and stays engaged until I turn off the AC button.
Any thing else I should look at?
Going to chalk this up as old German car being old German car and it's going to have a few electrical hiccups here and there.
Another question: does the HVAC control ever go bad?Last edited by zzyzx85; 09-06-2024, 03:02 PM."your BMW has how many miles!?"
2003 (2/03) M3 coupe Imolarot/Black 6 M/T - JRZ RS One 450/550 - Ground Control Street - SDW RTAB - TMS Street ARCA - Redish V2 - TMS solid subframe bushings - Volk Racing G2 18x9.5 - StopTech ST40 355 (coming soon) - Beisan Systems VANOS parts - WPC OE rod bearings - Karbonius CSL airbox - Kassel MSS54HP DME - Kassel MAP sensor - Euro headers and Section 1 - SuperSprint Sport - Recaro Speed - Schroth Rallye 4 QF - AS 30% SSK
build/journal
ig: @zzyzx85
Originally posted by Tbonem3 View PostWhoa bro he's just asking an innocent question chill out
*I think someone found out the f.a.g. hubs are being made in asia now'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Originally posted by PSUEng View PostI'm burning this thread up!
So for rear CV axles, referencing the "washers" and bolts connecting the axle to the diff output, TIS says: "Replace bolts and washers (1)". Does this mean re-install the washers and bolts, or replace all the washers and bolts with new parts?2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Mike02 M3 Titanium Silver/Black
11 Tundra SuperWhite/Black
16 X5
I believe the bolts are class 10.9. When I had the diff out to replace the cover, I reused them.
EDIT: Looks like the bolts bite into the plates, so depending upon which one is harder, I can start to understand the replacement. I might stick with just the plates...for now.Last edited by PSUEng; 09-08-2024, 02:10 PM.
I could get replacing the r/f plates, but those bolts? I'd like to know the reason BMW specs for them to be replaced, short of damage/excessive corrosion. My diff was out for a cover, and the fasteners re-used and no problem.
EDIT: Looks like the bolts bite into the plates, so depending upon which one is harder, I can start to understand the replacement. I might stick with just the plates...for now.2008 M3 Sedan 6MT
2012 Mazda5 6MT
Koni Special Active, Volvo parts
