    Would it be a waste of money buying a Genuine BMW clutch kit over a Sachs clutch kit? After reading some threads it sounds like it's best to just buy the Sachs clutch kit with the LuK TOB?
    /// 2004 SG/IR - Build Thread
      Originally posted by skylinekin View Post
      Struggling to find part number for the plugs that fill these holes on each side of the trunk lid…anyone have it?
      Took some measurements from my removed factory trunk lid.
ID:	361917 Click image for larger version
      Try this
        Originally posted by Avedis View Post
        Thank you kind sir! The pictures and dimensions are very helpful, I will add that one to my next order and give it a shot.
          What is the torque spec on the oil filter housing bolt? In my old Bentley, I have hand written 24ft-lb then scratched it out and wrote 18ft-lb; I don't remember why. The TIS states full flow lid style is 24 ft-lbs, which I guess is what this is ??
            It is different depending on where you look, 18ftlbs vs 24ftlbs.
            Since TIS has 22NM (~18ftlbs) for M8 bolt and 33NM (24ftlbs) for M10 and M12, we should know which it is if you can get the diameter of the bolt.
