    Would it be a waste of money buying a Genuine BMW clutch kit over a Sachs clutch kit? After reading some threads it sounds like it's best to just buy the Sachs clutch kit with the LuK TOB?
    /// 2004 SG/IR - Build Thread
      Originally posted by skylinekin View Post
      Struggling to find part number for the plugs that fill these holes on each side of the trunk lid…anyone have it?
      Took some measurements from my removed factory trunk lid.
ID:	361917 Click image for larger version
      Try this
        Try this
        Thank you kind sir! The pictures and dimensions are very helpful, I will add that one to my next order and give it a shot.
          What is the torque spec on the oil filter housing bolt? In my old Bentley, I have hand written 24ft-lb then scratched it out and wrote 18ft-lb; I don't remember why. The TIS states full flow lid style is 24 ft-lbs, which I guess is what this is ??
            It is different depending on where you look, 18ftlbs vs 24ftlbs.
            Since TIS has 22NM (~18ftlbs) for M8 bolt and 33NM (24ftlbs) for M10 and M12, we should know which it is if you can get the diameter of the bolt.
              An M8 bolt is typically a 13mm socket heat bolt, so 18 ft-lbs.
                It's a 13mm. I'll keep it at 18 ft-lb thanks! But just in case you guys are working on Toyotas they don't always follow the ISO convention as they spec some fasteners to have hex drives different from ISO in order to keep it less complicated in the factory from a tooling standpoint.
                  I have a dumb question regarding Schrick Cams.
                  I have the 272 Exhaust cam already.
                  Can the following part be used as the INTAKE?
                  0415A1800-00
                    Anybody know how to safely remove the Christmas tree pins from the bottom of the seat panels without damaging them? Or do you just need to buy new ones when installing the new back panels? I pulled out one the other day and completely destroyed it trying to get it out.
                      Some new error codes yesterday. I hardly use the AC (drive with the windows down), but yesterday was especially hot and when I took one of the cars to pick up the kids from school in 95* temperatures, I tried to turn the AC on. Snowflake would illuminate and turn off immediately, and the air speed would be limited to 50%. Ambient air temperature reached 110*.
                      Plugged in the laptop and got these two codes:
                      24 Additional heater relay
                      Error frequency: 10
                      short circuit to batt+
                      Errorcode: 18010A2445C088510386
                      255 Energy saving mode active
                      Error frequency: 1
                      short circuit to ground
                      error present
                      Errorcode: FF42012489CF88510375
                      Anyone with a similar experience?
                      David
                      Anyone experience this before?
                        I bought a Dinan intake kit and studying install, my laziness is really kicking in. Supposed to relocate the Xenon ignitor per Dinan instructions and I'm thinking, really? Can anyone chime in on the need for this? My OCD then kicks in with modifying the bracket and I'm like, well, gotta buy a new one of those to keep everything original...man I'm lazy these days. BUT--pulling the driver headlight to do this motivates me to pull the passenger side, and send out to Lightwerkz for the projector rebuild I've been delaying. So not all bad!
                        Just "upgrade" to the dual halogens and toss those igniters. You'll lose a few pounds off the nose of the car. I prefer the symmetrical look of the dual reflectors.
                          Interesting idea I never considered that, thank you. So you propose just replace xenon units with halogen? Is that plug and play? I was hoping to get some lighting improvement with the LW mod, however.
                            It is plug and play, but you need to code the high beams to work correctly. Only the flash to pass works since it was originally a bi-xenon and doesn't use the inner light for the highs.
