Originally posted by Doost
Really? Seems like the Front is already sticking out beyond the wheel arch without a spacer. Thank you for your input, my googleness is failing at the moment.Originally posted by Tbonem3 View Post15mm front, 12mm rear. 12/10mm is good too, but rear hub lips might need slight chamfering/grinding down to accomodate 10mm spacer due to hub extension/mating with spacer.
18x9 et26 you won't need any spacers on the front as you noticed. Tbone probably read over the fact you have a square set.Originally posted by jdamore44 View Post
Yeah, the pic is just after I put them on, I fully expect the front to settle more after I take it out for a drive. I'm also considering trading them for (4) fronts so I can put them on my XI Touring. I'm pretty sure these would rub on my touring? I have no plans of tracking this until I get the rear subframe/trunk floor addressed.Originally posted by r4dr View PostYeah, he definitely thought staggered. You would only want a 12mm in the rear, but TBH that front fitment is not great looking without some camber and a drop.
Are you on stock suspension?Originally posted by jdamore44 View Post
Yeah if you're talking E46 touring I think they'd rub since they don't have the wide fenders of the M3. You might be better off buying 4 fronts outright and running staggered on both lol.
I see you're in WA too, I love driving out to the peninsula during the summers.'03.5 M3 SMG Coupe - Jet Black / Black
Yup, stock suspension. It's on the list to upgrade right after my rear end reinforcement and Vanos bulletproofing. Going with Koni/Eibach. GC plates. I have stock set of 19's I usually run, so I definitely don't need two sets of 18's. I really don't know if I want to keep this for a track set eventually. Or sell them as is because I just got a good deal on them, and spent Saturday clay baring, polishing and ceramic coating them. I'd love to get a set to go on the Touring. I'd imagine I could find some members who would want to trade 2 fronts for 2 rears? Twice?Originally posted by r4dr View Post
Yeah man, up in PA, I haven't had my M on the road much at all over the last few years, (just did SMG to Manual swap last year), and nervous for rear-end and Vanos to grenade my good time. It would be nice to get together with some other e46 M owners as I haven't got to experience any other cars to compare the current health of mine. Let me know if you plan a trip out ! Thanks for your input too, I really appreciate it
Not out of the box, that's what the V2s are for. Problem with the v2s is that they're a different design so if you ever want to upgrade in the future you'll probably be swapping those out for the V1s.Originally posted by Syfon View PostSupersprint V1 Stepped headers - they have two 2.5" collectors at the bottom.
Section 1 (stock, euro, us, or aftermarket) all have a piping id of 2.25".
Is it possible to get Supersprint V1 Stepped headers (2.5") to fit a 2.25" Section 1?
Although, if you know how to weld I guess anything is possible.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I understand they will not fit out of the box.Originally posted by heinzboehmer View Post
I have the opportunity to purchase a used set for cheap (relatively). And given I'm doing my motor rebuild I'm thinking why not.
Basically what I'm asking; if I take the V1 headers + my section 1 (Status Gruppe) to a local exhaust shop, they should be able to custom fabricate a flange or even flare the 2.25" pipes to fit the V1's no?
Yeah any decent exhaust shop should be able to weld a flange on there to make them fit.Originally posted by Syfon View Post
Basically what I'm asking; if I take the V1 headers + my section 1 (Status Gruppe) to a local exhaust shop, they should be able to custom fabricate a flange or even flare the 2.25" pipes to fit the V1's no?2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Yes. If not you will have a big mess.Originally posted by DropTopKingM3 View PostReally stupid question here.
When changing the diff cover with the OE bushings, does the fluid have to be drained? Im about to order a new diff cover for my refresh but had the fluid changed back in May.
Thanks.
