Does anybody know the part number for the headlight adjuster screw? The plastic geared one to manually level headlights?
I don't think they sell that separately. If it's the internal piece that's broken and you have a 3d printer, you could try printing this: https://www.thingiverse.com/thing:3519408
Probably would need to be nylon to get the best results
Originally posted by terra View PostI don't think they sell that separately. If it's the internal piece that's broken and you have a 3d printer, you could try printing this: https://www.thingiverse.com/thing:3519408
Probably would need to be nylon to get the best results2008 M3 Sedan 6MT
2012 Mazda5 6MT
Koni Special Active, Volvo parts
Is the coolant temp gauge suppose to be dynamic meaning will it move around in between the two dots or is it suppose to stay at a certain temp and never move? My temp gauge will get lower when running on highway but always within the dots. Never has it gone over to the hot side of the range.
Originally posted by jixer77 View PostIs the coolant temp gauge suppose to be dynamic meaning will it move around in between the two dots or is it suppose to stay at a certain temp and never move? My temp gauge will get lower when running on highway but always within the dots. Never has it gone over to the hot side of the range.
in comparison, the E46 non-M is in the middle from 75°C to 115°C
Originally posted by DropTopKingM3 View PostIve seen a few yellow tag ZCP steering racks come up for sale. Ive been out of the loop with these cars so bare with me. What the difference with the actual yellow tag rack? How would this improve handling?
Thanks.I see a lot of misinformation regarding steering modifications being passed around Facebook groups and forums almost daily, so I’ve decided to put together this information thread to correct the many misconceptions, and to compile a comprehensive database for steering rack swaps and power steering modifications. The2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
What are the ideal tire sizes (for handing with a nod toward comfort if that's even possible on 19s) to put on ZCP wheels? The previous owner installed 245/35 and 275/30. I thought I remember reading somewhere not to go over 235 in the front on a staggered setup and I feel like 275 is a bit too large in the rear. It looks cool but I want to replace with the collective ' best setup'. I would also like to put a 35 series on the rear for more comfort if possible but I am not sure if that is optimal to maintain circumference or wheel speed sensor issues?
My car is an 06 ZCP, OEM plus I would call it.. the big 3 are done and I have a slight drop on coilovers using the approved measurement from the center of the cap to the fender if I recall correctly. (Dan Avon is local and set that up)
*ideally I'd like to get a square 18 setup but I love the ZCP wheel look and to replace it with something visually better is big bucks.
** or is the 18 square setup so much better that it's worth it in all regards and I should just plan on that?
Unless I receive different feedback, I'll assume that 235/35 and 265/30 are optimal but I wanted to check in this self described Safe Zone.
235/35/19, circumference: 80.0"
and
265/30/19, circumference: 79.4"
245/35/19, circumference: 80.9"
and
275/30/19, circumference: 80.1"
Proper tire size for all OE e46 wheels, save for true csl, is 225/255.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by FBloggs View PostDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by binary View PostWhat are the ideal tire sizes (for handing with a nod toward comfort if that's even possible on 19s) to put on ZCP wheels?
https://nam3forum.com/forums/forum/m...-sizing-thread3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
