    Picked up these old second hand seats for it πŸ˜‰
      Originally posted by E36 PWR View Post
      Blank steering wheel trim install, navigation delete, radio delete panel, HVAC relocation. Streamlined and driving focused.
      Dang. I really like it, but I use my steering wheel buttons too frequently to delete them.
      997.1 GT3 Carrara White/Black
      C43 AMG Diamond Silver/Red​
        Very cool, where did you mange to source these? They look to be in quite good condition as well.
          Did the radio delete and jb welded the plastic and pin back to the center dash trim.
            Thanks! They're a pair that NZ_M3 has had sitting on his shelf for the last ten years. They were originally from a low mileage car and having been stored for half their life means that they're in incredible condition.
            This will probably be the one time ever I was at an advantage sourcing M parts living in New Zealand. Usually my location is to my detriment when it comes to the car πŸ˜‚
              Called the tow truck.....
              Put the car on stands to do an oil change a when the plug came out realized the previous "shop" had stripped the oil pan threads and threw a helicoil in there to plug it up. So now she stranded with no oil......... fun times.
                That’s SO fuqqqkd up! You buy these cars because everyone can fix them, then the everyone you hire to fix them is busy breaking them. Fun times indeed.
                maw
                  That's SO fuqqqkd up! You buy these cars because everyone can fix them, then the everyone you hire to fix them is busy breaking them. Fun times indeed.
                  maw
                  But if you fix it badly this time you might get to bill to fix it again next time πŸ˜›
                    Were gonna try to retap it. If thats a no go then new oil pan it is.
                      Very nice. Enjoy
                        karter16 Awesome seats! I'm curious if the CSL seats have the driver sitting centered to the steering wheel. It's been a while since I last sat in CSL seats. The Nogaros felt like they were off-center by quite a bit, forgot if it was left or right.
                          Yeah nogaros are noticeably offset towards the doors (so left of the steering wheel on LHD cars). Not something I notice when driving anymore, but it did bother me a bit when I first got them.
                            Dinan RTABs, Solid Rear Subframe bushings, 3.91 diff with new diff cover, powder-coated rear subframe, powder-coated rear lower control arms, powder-coated diff carrier bracket, bimmerworld rear camber arms, vincebar epoxy/rivet version, vinceskinz lower weld in plates for reinforcement.
                            Car should be back on the ground next week and then the weekend after swapping out the suspension again for ohlins r&t, gc camber plates, meyle rsm, hotchkiss front sway bar, turner adjustable front end links, fresh alignment and corner balance
                              Just got a LSB m3 recently, had vanos, spark plug, engine mounts done. What a difference...if anyone has dove grey coupe seats please let me know
                                Joni has a set of mint dove coupe seats. Hit him up on IG "BMWRestoredSeats"
