    I did a thing...
    Bring on the haters LOL
      As long as the guts are M
        I think I can check that box. See: https://instagram.com/e46m3teurotrip
          Originally posted by puma1824 View Post
          Click image for larger version  Name:	IMG_0591.jpg Views:	31 Size:	167.7 KB ID:	240540
          Click image for larger version  Name:	IMG_0593.jpg Views:	32 Size:	154.1 KB ID:	240537
          Click image for larger version  Name:	IMG_0596.jpg Views:	31 Size:	110.8 KB ID:	240538
          Click image for larger version  Name:	IMG_0598.jpg Views:	32 Size:	169.0 KB ID:	240541
          Click image for larger version  Name:	IMG_0600.jpg Views:	33 Size:	154.3 KB ID:	240542
          I did a thing...
          Look more like a 332is than an M3
          Seriously, beautiful build. One day I will build one!
            Originally posted by Bogart79 View Post
            Replaced inner tail lights 20 yr old vs new
            are these OEM or aftermarket? I need to replace mine...
              Sucked her dry and filled her back up with new oil and filter.
                oblique
                  I did a thing...
                  I was thinking of doing that to mine but I have it just blanked at the moment !
                    You have a conversion too? Have pics or build thread?
                      I did a salmon relay R&R and what may be my last ever SMG bleed and adaptation procedure. Didn't save me from my not-engaging-second-gear problem. Manual swap here I come.
                        I leak tested my Karb box and need to be sealed.
                        The warranty process did not work out too well for me so I will seal it myself.
                          Picked up some 219Ms today. '09 date code Pilot Sports on em. Thinking about 245/40 and 275/35 size tires. The old PS rears are 265/40, but I believe that would give the DSC a bit of grief with the big circumference delta
                            ^^^ nice plate.
                            maw
                              How did you seal it? Thx
                              I used loctite 9460 and apply a bead all around the seam of the two airbox halves and spread it to ensure all gaps were sealed. I will smoke test it on the weekend to confirm it worked. The epoxy I used has has. 72 hour cure time.
                                Which error code is displayed?
