    Pulled the wheels off and cleaned all the rubber off after 3 days at The Glen and 2 days at NJMP Thunderbolt
      I leak tested my Karb box and need to be sealed.
      Production date of box?
        Mine is one of the first batch, Oct 2022
          So I took it off, always a nice sight the S54 is.
          How did you seal it? Thx
            Originally posted by sleepyonthehighway View Post
            after a couple months, what are your thoughts? i’ve found heel-toeing (when not in sport) to be very awkward. i had my technique dialed in on the previous car.
            I wear a size 11.5 shoe and have a hell of a time hell-toe'ing in this car. I can do it, but I have to think about it, which makes me slow.
            2004 Dinan S3-R M3
            2023 X3M Competition
              I wear a size 13 shoe and struggled with heel toe as well! Mostly because my brake pedal moved too much below the throttle. I added some spacers to raise the brake pedal up and it helped. I never really got it to the point where I was totally comfortable with it.
                Size 11 here. I wear DC skate shoes when driving. The smaller footprint (literally) and increased feedback from the softer, thinner sole helps a ton with heel toe.
                  You should install AKG Motorsport brake and clutch pedals bushings. No more side play in pedals after. Feels way better!
                  For heel & toe, E46 M3 is super easy to blip but don’t try to actually do it with your heel and toe. Try to brake with the ball of your right foot and blip the accelerator pedal with the side of the foot. See video here:
                    Start wearing foot shaped shoes and toe spacers you'll be able to do it easier in a month.
                      For heel & toe, E46 M3 is super easy to blip but don't try to actually do it with your heel and toe. Try to brake with the ball of your right foot and blip the accelerator pedal with the side of the foot. See video here:
                      https://www.youtube.com/watch?v=_AR1LaW_edY
                      Yup had those bushings installed and using the same technique. Side to side play wasn't really an issue but those bushings did feel great.
                      Issue was under hard braking the brake pedal went too far down below the throttle that you risked hitting the throttle while braking. Technique totally fine on the street but failed on track. My ankle must not bend as much as most people.
                      I'm SMG now so no more issues. But I would highly recommend others who are struggling with heel toe to see how far the brake pedal travels and try to correct it as much as possible. At full braking you want the brake pedal slightly higher than the throttle. Some of the spec E46 guys have similar issue and end up removing the brake pedal and brazing/bending it so that the pedal sits higher.
                        Went to a car wash (one of those laser / no touch ones). Realized that with the Karbonius trunk lid, the trunk gets wet / damp.
                        Wonder if it is the alignment or lack of seals / gaskets, etc.
                          Car washes are sort of unfair. Very high pressure water at all sorts of angles. More than you will ever see in an actual storm.
                          Had similar issue with a different cf trunk. Got some generic weather seal strips from amazon. Also had to adjust the trunk stops to the lowest setting where it would still unlatch when unlocked. Make sure where the seal seals there is no dirt or debris. Garden hose is an easy test to see if it works.
                            Installed a Euro bumper, replaced some of the missing foam pieces on top of the reinforcement bar using an old broken RC airplane wing, I would say it fits a bit better than the factory bumper.
ID:	239005 Click image for larger version
ID:	239006 Click image for larger version
ID:	239007 Click image for larger version
ID:	239008 Click image for larger version
                              I need a lift make my life easier
                                Went for a drive with some forum members. Weather was a perfectly cool, autumn day. One of those days when you bounce between windows up and down. Perfect.
                                We will do this again, Southeast members.
