    Originally posted by Andy2424 View Post
    Which error code is displayed?
    I don't remember off the top of my head. Something about the gear position reading when reading with INPA. The problem also happens on 2->3 shifts as well.
    On an upshift, the shift will occasionally not execute. The ECU then holds the engine RPM at a level that would match the previous gear, clutch stays disengaged (or trans is in N), and the SMG goes totally unresponsive. Have to shut down the car to reset it.
    Edit: found a pic I took when I tossed the Foxwell reader on to see what was happening:
      I used loctite 9460 and apply a bead all around the seam of the two airbox halves and spread it to ensure all gaps were sealed. I will smoke test it on the weekend to confirm it worked. The epoxy I used has has. 72 hour cure time.
      Thanks! Looking forward to hear back on the results.
        A little RIT goes a long way.
ID:	240870Click image for larger version
        ‘02 TiAg/Impulse Slicktop
          RIT?
          maw
            RIT?
            maw
            Name of the fabric dye I used for the parcel shelf. Not the best picture but here’s how it looked beforehand.Click image for larger version  Name:	IMG_6676.jpg Views:	0 Size:	53.2 KB ID:	240885
              Looks great (The after picture)
              Did you dye the shelf without removing it?
                That’s what I thought. Looks great… new actually.
                maw
                  Thank you!…I saw someone do it once without removing it using index cards and a brush but I ended removing it and using a spray bottle. Plus I wanted to clean the vent (was dusty) and fully clean the rear glass. The job isn’t too hard, just gotta watch out when taking the C pillars off and the rear seat bolsters because the plastic mounting points might break. Otherwise, could be done on a day off.
                    RIT?
                    maw
                    Dye
                      I finished the sealing. The process was a bit finicky, and you need to be very careful to not spread or put resin where you don't want to, the good news is that when fresh it cleans very easily. I bought the applicator gun, and nozzle, but you can just squeeze the product on a mixing tray and mix with a wooded stick and apply and spread. I bought a small silicon batter spatula, to apply a bead of product on the areas where it leaked I finally used my finger to evenly spread a mix. not that it matters to be super sharp with it, but I did try to no make an f'ing mess. I think I got it all right, this weekend and will smoke testing it again to confirm.
                      the only downside is that this product dries light gray, it would be perfect if it was black, but again, is inside the box and you wont be able to tell 99% of the time.
                        I'm assuming that Gear recognition sensor SMG 2 suitable is closed!
                        sorry is in german
                        In the video it's third gear, but it doesn't matter! It's usually second or third gear!
                        I bought it her https://burkhart-engineering.com/sho...-inkl-csl-bmw/
                        Try soldering the circuit board
                          Z4 manual dimming rearview mirror. When it comes to this car, I like simple.
                            Avedis what was the part number again for this?
                              51-16-9-134-400
                                sorry is in german
                                I can take a look at my sensor next time I get the car in the air, but ordering a new one is almost out of the question at $800 US. I can get a manual shifter, knob, boot, trim etc. for that price.
                                My SMG needs a pump motor and/or accumulator too as the pressure holding is just out of spec.
