Originally posted by nahvkolaj
Originally posted by Andy2424 View Post
Which error code is displayed?
On an upshift, the shift will occasionally not execute. The ECU then holds the engine RPM at a level that would match the previous gear, clutch stays disengaged (or trans is in N), and the SMG goes totally unresponsive. Have to shut down the car to reset it.
Edit: found a pic I took when I tossed the Foxwell reader on to see what was happening:
I used loctite 9460 and apply a bead all around the seam of the two airbox halves and spread it to ensure all gaps were sealed. I will smoke test it on the weekend to confirm it worked. The epoxy I used has has. 72 hour cure time.
Originally posted by Sprp85 View Post
Looks great (The after picture)
Did you dye the shelf without removing it?
RIT?
maw3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Thanks! Looking forward to hear back on the results.
the only downside is that this product dries light gray, it would be perfect if it was black, but again, is inside the box and you wont be able to tell 99% of the time.Last edited by maupineda; 11-06-2023, 06:12 PM.
Originally posted by nahvkolaj View Post
I don't remember off the top of my head. Something about the gear position reading when reading with INPA. The problem also happens on 2->3 shifts as well.
I'm assuming that Gear recognition sensor SMG 2 suitable is closed!
SMG, M3, E46, BMW, INPA, Gangsensor, Gangerkennungssensor, Wahlwinkelsensor, Fehler, Getriebe, Anlernen, Adabtion, Löschen, neu, Tauschen, Probleme, Reparieren, mForum, AIC-PX, Wahlwinkel, Gangerkennu
sorry is in german
In the video it's third gear, but it doesn't matter! It's usually second or third gear!
I bought it her https://burkhart-engineering.com/sho...-inkl-csl-bmw/
Try soldering the circuit board
