    I’ve never been so happy to receive a set of carpets. Even scored the OEM trunk mat!!
    Current:
      I know this is different between the sedan and coupe, but are you saying there are only a couple points of contact between the bow and the pillar (where the spot welds are)? Looking at pictures of the bows makes it seem like most of the surface area on the "ears" of the bow comes into contact with the pillar, as they look contoured to match.
      Rivets would only be used to hold the bow and ensure that the epoxy dries at its optimal thickness for max strength, so those wouldn't really be structural once everything is cured. If there's enough of a contact patch, couldn't you just drill the holes for the rivets in places that don't interfere with the existing spot welds?
      Yes you are correct Coupe and sedan bars do have flat mating services. You could drill different holes for the rivets if you wanted to You just need to make sure to avoid the spot welds that are behind the support bar so you don't drill through them.
      Sent from my Pixel 4 XL using Tapatalk
        Where did you find the trunk mat?
          Awesome, thanks for the info. I'll have to look into it more when I (eventually) do my carbon roof. Super tempting to do epoxy since I don't have to get a welder to come out, but we'll see.
            Pulled off the roof skin in preparation for the sedan carbon fiber roof
            Sweet man!!! Did you remove the F+R glass yourself? Where in the ATL are you located?
              No I have a friend that runs a auto glass business I had him come out and remove the front and rear glass for me.
              I'm located in Lawrenceville Suwanee area which is about 45 minutes from north of Atlanta off 85.
                Clutch bushings, bronze.
                PIA, but a necessity.
                2004 M3 Mystic Blue
                  Finished splitting my O2 harness and re-routed the rear sensors to follow the fuel lines and connect with my new Supersprint Section 1 cats.
                  '01 M3, JB/IR, SS, TCK DA, Apex, TMS CSL, HTE, 4:10 gears - original owner
                  '00 slicktop Touring converting to full M3 Touring
                    Did you do brake pedal too?
                      Nope, brake seems good.
                      clutch was horrendous, a he## of a lot of side play. No difficulty telling the difference b4 and after.
                      2004 M3 Mystic Blue
                        Ya it's nice with the bronze in. I even got rid of my Mason clutch pedal as stock was perfect with the new bushings.
                          Break in period for the new 3.91 diff is over so I dumped in some more liquid gold.
                            These bad boys arrived yesterday and got them installed today
                            Went for a joyride. Nice weather too
ID:	91307 Click image for larger version
ID:	91308 Click image for larger version
                              Measured an abysmal 40bar of pressure at vanos after it was fully rebuilt, meh.
                                What's the healthy/normal pressure range? This is my next major maintenance item to be addressed.
