    Well after 9 years of flawless SMG ownership the car threw SMG codes 36 and 37 on the way to work this morning and again on the way home. Not the worst timing as was planning to have the car in the air soon for the RACP brace install, so can do the gear position sensor at the same time. I look forward to spending 500 Euro on a new one…
    LOL just get a used one.
      Well after more than 9 years of E46 M3 ownership I finally joined the flatbed gang. The GPS died on me entirely quicker than I was anticipating and left me with a box full of neutral this morning. Car is now at Dad's ready to be worked on. bmwfnatic (thank you!!!) is picking up a new sensor this week and fedexing it to me.
      Had been going to do the RACP brace about a month ago but wasn't feeling up to it at the time, glad I didn't as can do this at the same time.
      Build Thread:
        Had a great weekend working on the car. On Saturday morning Dad and I got the car up on stands and exhaust and driveshaft out. Unbolted the exhaust at the headers and dropped the whole thing, then the same with the driveshaft. So much faster than last time given we're just removing and reinstalling rather than taking it all apart to clean. I'm super happy with how everything under the car is holding up, it's 8 years since we did the underbody refresh and everything is looking really good under there.
        I did the new gear position sensor first, access is a bit of a mission but the mutilated allen key approach does work. The old sensor was extremely notchy and rough after 20 years of service. Worth noting that we ran the first part of the SMG adaption (up to the point it wants the car started) to make sure it was happy with the new GPS.
        After that we moved on to lowering the rear subframe to facilitate the installation of the Yurkan Cages 6 point brace. We took off the brake calipers and rear trailing arm pockets and lowered the entire thing about 100mm on a couple of jacks (to give us more control over forward/rearward weight distribution). That gave us enough access to unbolt the front RACP studs and get them out. We then jacked the subframe back into place and loosely bolted it, which gave us a better safety factor while working under it.
        At this point we drained the diff, swapped out the rear diff cover for a new one and reinstalled with new bolts and drain plugs. I've mentioned previously that I'd long experienced some clunkiness when shifting/loading/unloading the drivetrain. This was vastly improved by adapting the SMG. I wasn't sure whether what remained was the diff getting a bit tired or whether the rear bushes needed replacing but I was pleased on checking the diff that there is no detectable lash in the diff at all, likewise with the driveshaft. I was therefore pretty hopeful that it was just the rear diff bushes that were the culprit.
        The rest of the process was pretty straightforward, we unbolted one point at a time and using a threaded drill guide that dad turned on his lathe and an extra long 6mm drill bit we went up through each of the 4 points in turn. Then it was simply a case of come down from the top with a 10.5mm bit before running a tap on a long extension up from underneath to complete the thread the whole way through. With that done it was then a case of bolting in each of the 4 points and torquing to spec.
        The rest of the reassembly took a couple of hours and we had the car on the ground again. The install of the brace was super quick - fitment of the brace was absolutely perfect - Marin's fabrication is spot on. Then it was just a case of running the complete adaption on the SMG and going for a test drive.
        Today I drove the car on a route I'm very familiar with and I'm extremely pleased with the end result! The last of the clunkiness when shifting is now resolved. Even under heavy acceleration in S5/S6 all you get is the sound and surge of power. I'm super stoked.
        And the brace. Well, I know others have reported a big improvement, but I wasn't completely sure if I'd find the same. Suffice to say the improvement is not subtle! For me the rear has always felt slightly less co-ordinated than the front (not to say it's not objectively excellent to begin with, but it's always stood out to me that the car is just a little bit more put together in the front). Now with the brace it's the other way around! The change in stiffness is hugely noticeable even just driving around town. As soon as you get to a roundabout or uneven tarmac it becomes very apparent how much more rigidity there is. The car really feels glued together in the back now.
        I love it and am excited to go for a decent spirited drive.
        Build Thread:
          Torrential rain yesterday and today so I can't do any work on my retaining wall at home. Got round to a little job I've been wanting to do for a while. The trim around the SMG shifter boot makes an annoying plastic on plastic creak sometimes when shifting, which isn't particularly pleasant from a driving experience point of view.
          Today I took the trim apart and used some tesa tape to insulate the clips and mating surfaces. I also gave everything a good clean while I had it apart. Put it back together and the squeaks are completely gone (unless I press very hard directly on the plastic trim), shifting is now a satisfying mechanical click, rather than the annoying creaking sound it could be before.
          Build Thread:
            I realised I never really updated on the bracket for the SMG reservoir. Since I installed the CSL airbox I've been running a prototype version of the bracket. Given it's a rainy Thursday here I thought since I'd proved the concept that I'd design up a more final version of the bracket.
            This is still a development version and you'll note there's a few things that need to be tidied up, but didn't want to go to too much effort until I've confirmed fitment of this latest version.
            I started by using my previous prototype to confirm the location of the bracket itself and mark where I wanted it with some blue masking tape. I then scanned the strut tower and loaded the (fairly untidy) mesh into Fusion to help with placing reference planes, etc.
            Click image for larger version  Name:	Screenshot 2025-04-17 at 11.44.59 AM.png Views:	0 Size:	1.25 MB ID:	301983
            Because the tower is an irregular shape the bracket needs to account for this:
            Click image for larger version  Name:	Screenshot 2025-04-17 at 11.51.35 AM.png Views:	0 Size:	142.8 KB ID:	301984
            Note that the final unit will have rubber stand offs on the back to help it sit well on the tower and not rub.
            The mounting point where it's attached to the stud on the strut tower also has a raised, angled boss as the stud is not perpendicular to the strut and this needs to be accounted for so that the nut clamps the mounting point properly.
            Click image for larger version  Name:	Screenshot 2025-04-17 at 11.51.25 AM.png Views:	0 Size:	154.3 KB ID:	301985
            I'll get this version printed up and do another round of test fitting and any final adjustments before I tidy up the rough edges. Given my goal of not wanting to drill holes in my strut tower I think that this should be a pretty tidy end result.
Name:	Screenshot 2025-04-17 at 11.51.29 AM.png
            Build Thread:
              Great effort as always my friend. BUT SMG Pump relocation is the only way to go with SMG cars. Glad i already did that.
                Thanks! My car is RHD which makes a relocation a bit more involved as both the "drug bins" are already full.
                Build Thread:
                  Oh I didn't realize that LOL. Makes sense now.
                    Sill waiting for the ground to dry out a little bit before I progress the retaining wall so spent a couple of hours this afternoon taking the rear sway bar brackets and v brace off and cleaning them up. When Dad and I did the underbody refresh in 2017 we used an enamel black paint for most of the pieces, and 8 years on they still look amazing - wipe the road dust off and they look brand new still. There were a couple of pieces (the sway bar brackets and v brace) which we painted with exactly the same stuff, only silver instead of black. Unfortunately the silver kind of sucks in comparison to the black - presumably whatever they put in it to make it silver makes it more susceptible to surface rusting.
                    So anyway - I took them off, stripped the enamel with acetone and then cleaned up the surfaces with some fine sandpaper before cleaning again with acetone and then undercoating.
                    The pictures are a bit average because it's pretty late in the day here, but I'm sure you've all seen undercoated things before:
                    Had something interesting happen when I was spraying the undercoat on. It went on beautifully and then I noticed along some of the edges that it looked like it was bubbling. *Cue confusion*. The surface was prepped well and was very clean so I wasn't sure what was going on - I've used this undercoat a bunch of times and it's always been lovely.
                    Closer inspection revealed it was moisture beading on top of the paint. Actual paint surface is fine and the moisture evaporated again. I'm guessing that it must be close to dew point here right now and the propellant from the spray paint has cooled the surface of the metal just enough at the edges for moisture to condense.
                    Anyway - the moisture evaporated after some minutes and the paint surface seems good. I'll double check it when it's set to make sure it has good adhesion.
                    Build Thread:
                      Another rainy day here so retaining wall is again on hold. I took the opportunity this morning to finally redo the matte screen overlay on the Xtrons head unit. I got the Xtrons about 16 months ago and have had a much better experience with it than I was expecting. I'm well decided that I'll be keeping it. one of the downsides of it, and many head units is the glossy screen. About a year ago I purchased a matte screen overlay to see if I liked it better. I did my best to line it up nicely but because I had to cut it to size the edges were visible and annoying to me. I've long intended to take the head unit out and disassemble it so that I could replace the overlay over the entire LCD screen so that the edges would be hidden by the bezel if that makes sense. Today was that day.
                      Head unit out:
                      Rear case off:
                      Disconnect the two big ribbon cables between the chassis and the display and remove the 4x screws holding the display shield on.
                      Then the display and shield pop out of the bezel:
                      The screen with the old matte overlay on it:
                      Old matte overlay removed:
                      I didn't get any photos of applying the new overlay as both my wife and I were employed in getting it on and keeping the screen completely free of dust. We succeeded and the overlay went down perfectly:
                      The new overlay with the protection layer removed:
                      Then it was just a case of reinstalling back into the bezel:
                      And reconnecting the ribbon cables and putting it all back together:
                      I'm super happy with how this has turned out - we got the overlay to go down perfectly and it looks fantastic:
                      While I had the unit out I took the opportunity to plug in the USB extension and install the latest firmware to address the issue with a greater than expected difference between volume levels 4 and 5. This was straightforward and did indeed fix the issue.
                      Now that it's reinstalled I'll give the screen and the head unit a clean to get the fingerprints from install off.
                      Good, quick rainy day project :-)
                      Build Thread:
                        Today I also finished up the repainting of the v brace and rear sway bar brackets project. I top coated them a week and a half ago and they've been resting while the enamel fully cured. Today I reinstalled them along with new hardware to match.
                        Build Thread:
                          Great updates as usual. Do you have a link to that screen protector?
                            Yeah sure - the one I got is a local brand - but should give you an idea of the sort of thing I used: https://screenshield.com.au/products...LSXH4mF.WHCYV2
                            Build Thread:
                              Well 2 days of driving an excavator, 4 months of weekends, 300m of rebar, 14 tonnes of concrete, 232 CMU blocks, and a lot of manual labour my retaining wall is complete - finished backfilling it today. Starting to get a bit wet here for the winter so great timing.
                              Bit of a general update on the car.
                              • The latest version of the SMG reservoir bracket is in use, I've got some more tweaks to make to it so will do that and print the latest iteration.
                              • The MAP sensor adapter in CF-PETG shows some evidence of softening. It seems, under the clamping force of the bolts, it's not quite up to the ~100 degree C temperature that the rail hits. Plan is to get this printed in GF-Nylon which should be able to handle beyond 150 degree C temps.
                              • I'm doing some preliminary work on the reinstallation of the trunk interior with the RACP brace in place. Working through a few things to get to a lightweight, high-quality solution that meets my need to make it look as OE as possible.
                              • The version of the CSL tune I've been running the last while seems super stable. Even as it's got colder here it's remained super smooth. Seems I've got the warm-up maps pretty much spot on. I still want to do some more fine-tuning, and in particular am keen to try out running the fuel tuning process with the MAP sensor integrator turned off, but it's not top of the priority list given what I'm currently running is so good.
                              • Planning to get the headliner out and off to the pros to redo with the BM-134 fabric that I have stashed. I've also got brand new A/B/C pillars to go in once it's reinstalled.
                              • Intend to make more progress with the 0401 disassembly as well - especially as the days get shorter and the weather gets worse.
                              Lots of little bits and pieces on the go.
                              I've also been enjoying driving the car. The refreshed diff bushes have eliminated any remaining clunk in the drivetrain. Combined with the smoothness of the CSL tune it makes for lots of enjoyable downshifts with no need for the manual throttle modulating that I'd previously gotten used to to minimize the thunk. Secondly the RACP brace has, in addition to providing top-side support to the RACP, made an enormous difference to the torsional rigidity of the rear of the car. It's a very significant improvement and I'm getting itchy to give the front of the car similar treatment
                              Build Thread:
                                Manufacturing for my design is close to being done! Should be in my hands in a couple weeks. Once finalized, installed and validated, I'll make it available for all.
                                Not sure what your plans are for the front end, but I guess I'm just excited to get my braces installed
