This is a sticky topic.
    For HVAC blower motors and FSRs, which brands are people using? I thought we had a thread somewhere with OE/OEM/Genuine parts listed out and what to avoid; maybe that was old M3F??
      I ordered an OE blower online from a dealer (might have been getbmwparts.com?). I have a Hella/Mahle "OEM" FSR on-hand just in case the generic made in China one I installed in an emergency decides to die.
      2007 GX470
      build/journal
      ig: @zzyzx85
        Seems the German made REIN FSRs are GTG. Genuine for the blower seems the best due to erratic fitment issues w/other brands.
          I'm removing my Hard Motorsports radio delete panel and doing the OEM one with HVAC relocated underneath and I can't remember what all's needed besides the frame, delete panel. Any extra screws so forth? Click image for larger version
            So I read some conflicting threads that confuses me. Does the rear strut reinforcement plate go above or under the body where it mounts?
              They go above, inside the trunk. https://www.ecstuning.com/b-ecs-part...002478ecs01kt/
              2007 GX470
              build/journal
              ig: @zzyzx85
                Ended up with ACM brand, apparently made in Germany and OE per FCP; hoping this one is GTG. I'll go Genuine for the blower.
                  Thanks!
                    What are you guys running for fuel injector/system cleaner?
                    2003.5 BMW M3 Carbon Schwarz Metallic/Cinnamon 6 Speed – HTE Tuning | Kassel CSL DME | AA Headers | AA Section 1 | SS Resonated Section 2 | SS Race Section 3 | TMS V2 CSL Airbox | TMS Street Plates | Ohlin’s R&T Coilovers | Ground Control Front and Rear Sways | Ground Control Adjustable Camber Arms | DMG Autosport Pro46R | FreakyParts BBK Front | Porsche 996 Conversion Rear | CMP Stage 1 + 1.5 Reinforcement Plates | CMP Subframe Bushings | CMP RTAB’s | Euro Bumper | SGT CSL Trunk | Dr VANOS
                      Shell V power
                        I've used Redline "Complete Fuel System Cleaner - Powersports" (link) in the m3. Could be placebo effect, but seemed to run smoother.
                        And I've used a few ounces of Marvel Mystery oil in my 330 when the fuel pump making strange noises. It was pretty loud (it only had 30k miles on it). Surprisingly, after 1 tank with MMO, the fuel pump sounds normal again and haven't returned after 1000 miles or so. Coincidence? Possibly.
                        YMMV.
                          Shell V power
                          V Power FTW
                            YMMV.
                            Appreciate it. Thanks
                              What is the smaller pipe that sticks out of the gas filler neck? Like, what is its purpose? Evap or something like that? I cracked the red plastic attachment while disconnecting the filler neck and I'm thinking JB-Weld unless this could cause safety hazards... so that's why I'm asking. What would happen if this leaked? Fire hazard or gas smell?
                              Click image for larger version  Name:	image.png Views:	0 Size:	75.9 KB ID:	220191​
                                It should be a sealed system. Any leak in the system will cause a strong fuel odor at a minimum.
