My car was broken into a few years back. They stole a few things in the backseat. They also popped the hood but apparently didnt take anything. However after that my radio is just static. I can play cds and my ipod no problem. Its a factory radio with a ipod plugin. Does anybody have an idea what happened? Did something in the engine bay cause my radio to stop working?
Originally posted by Laminads View PostMy car was broken into a few years back. They stole a few things in the backseat. They also popped the hood but apparently didnt take anything. However after that my radio is just static. I can play cds and my ipod no problem. Its a factory radio with a ipod plugin. Does anybody have an idea what happened? Did something in the engine bay cause my radio to stop working?
After installing a CSL airbox, what's the way to secure the xenon headlight control unit on the driver side besides the tab?
edit: I guess I'm missing an "expanding nut" that's inserted into the square hole in the fender/sheetmetal.Last edited by zzyzx85; 03-28-2022, 09:39 AM."your BMW has how many miles!?"
2003 (2/03) M3 coupe Imolarot/Black 6 M/T - JRZ RS One 450/550 - Ground Control Street - SDW RTAB - TMS Street ARCA - Redish V2 - TMS solid subframe bushings - Volk Racing G2 18x9.5 - StopTech ST40 355 (coming soon) - Beisan Systems VANOS parts - WPC OE rod bearings - Karbonius CSL airbox - Kassel MSS54HP DME - Kassel MAP sensor - Euro headers and Section 1 - SuperSprint Sport - Recaro Speed - Schroth Rallye 4 QF - AS 30% SSK
build/journal
ig: @zzyzx85
When installing aftermarket seats and the airbag light illuminates....
Does adding a passenger seat occupancy bypass allow the airbag to work properly or just turn off the dashboard light?
The way this is described in the ebay listing is unclear to me.
Thank you!
The airbag light would come on if you left the battery connected while unplugging things.
This emulator will tell the car that someone is sitting in the seat so the airbag will go off in an accident (whether there is a person in the seat or not).
If no emulator, the airbag wouldn't go off if even if someone was sitting in the seat.
Your aftermarket seats can't tell the car whether someone is sitting there or not.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
- Likes 3
I swapped steering wheels my new wheel tilts to the right slightly as compared to the last wheel which sat centered.
The last wheel and the new wheel are both aftermarket items, but of course they were both built around an OEM core.
My alignment is off and the car does pulls to the right, the vehicle is getting an alignment soon.
Should I re-posiotion my wheel so the 2 "tick marks" line up regardless of that causing the wheel to lean to the right wheel driving straight?
Currently I have the new wheel with the tick mark one postion off of the tick mark on the column to compensate for the wheel not sitting correctly.
It is strange as the splines in the wheel (and I assume the tick mark) are they same on every wheel, as in they should all be in the same location.Last edited by Cubieman; 03-31-2022, 03:08 PM.2004 Silbergrau Metallic 6MT
Originally posted by Cubieman View PostI swapped steering wheels my new wheel tilts to the right slightly as compared to the last wheel which sat centered.
From the TIS manual for steering wheel install:
Installation -
Move wheels to straight-ahead position.
Align steering wheel using marking to steering column and attach. The retaining pins must also appear in the openings in the steering wheel.
Slideways I am getting an alignment tomorrow, do you think I should set my wheel so the 2 tick marks line up or leave it?
As posted above I currently have the wheel one spline CCW from the marks lining up to keep the wheel staight while driving.
When they do the alignment won't adjusting the tie rods to straighten the wheel also affect toe, thus affect the alignment?
If that is the case should I line my wheel up "correctly" to the column even though it leans to the right?Last edited by Cubieman; 04-03-2022, 06:40 PM.2004 Silbergrau Metallic 6MT
Originally posted by Cubieman View PostSlideways I am getting an alignment tomorrow, do you think I should set my wheel so the 2 tick marks line up or leave it?
Originally posted by S3diment View PostHave Vorschlag camber plates and went for my first alignment. The shop asked if the plates were installed correctly because they didn’t know how to adjust the camber. I’m pretty sure I did them correctly, is there a procedure to adjust the camber properly?"your BMW has how many miles!?"
build/journal
ig: @zzyzx85
As long as you followed the markings on top of the plates, it's hard to mess up the install. They should be able to slide the camber plate in and out after the 3x strut mount nuts are loosened up and the suspension is unloaded.
I just had my car aligned at the dealership, I have offset BC camber plates. They thought that they were installed backwards and swapped them with the same result. The plates don't sit centered in the strut tower so you cannot easily adjust them like normal plates.
I ended up paying $600 for a f**king alignment as a result, I should have argued my case more, but I got an additional 3 hours labor (at 1/2 rate supposedly) for them to swap those plates. What a mess.
Originally posted by Cubieman View PostI just had my car aligned at the dealership, I have offset BC camber plates. They thought that they were installed backwards and swapped them with the same result. The plates don't sit centered in the strut tower so you cannot easily adjust them like normal plates.
Bonus points if you find a place that has a couple e46 m3 track cars parked outside.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
