That’s completely unacceptable. Are you sure you were shipped the correct part number?
I may have ordered the wrong part, look at the top of my post for the edit with the part I ordered/installed and the part I placed an order for after finding out about the fitment issue.Originally posted by BMWE46M3 View PostThat’s completely unacceptable. Are you sure you were shipped the correct part number?
I should have checked realoem before ordering, I didn't think there was two different coils. Hopefully the difference is in the width as the part I received fit well except for the exposed sides.2004 Silbergrau Metallic 6MT
I ordered 2894 back in 2020 and it fit perfectly. That other part you bought is definitely not the correct one.Originally posted by Cubieman View Post
I am on a roll today... $85 sunroof seal won't fit without cutting it, awesome!
This IS the correct part number compared to my windshield cowl.
Appears to be an Autosolutions SSK.Originally posted by bavarian3 View Postin the middle of an interior swap, thinking through what solution to get for the shifter as it's notchy as hell.
Anyone seen this shifter and boot before? PO changed from stock to a "short shifter" but couldn't recall the type, brand.
Regarding replacing motor mounts, do any of the exhaust components have to be disconnected (like header to section 1 connection) or can the engine be lifted with an engine support bar without having to disconnect any part of the exhaust?
I finally resolved and fixed my exhaust leaks not even 6 months ago and really don't want to disconnect any part of the exhaust and go through that again, to install Bimmerworld motor mounts.
No need. If you're holding the engine with a support bar from up top, then you can drop the subframe slightly and it'll make you life a lot easier.Originally posted by BigRussia View PostRegarding replacing motor mounts, do any of the exhaust components have to be disconnected (like header to section 1 connection) or can the engine be lifted with an engine support bar without having to disconnect any part of the exhaust?
Undo top nuts from the engine bay, go under the car and undo bottom nuts, drop subframe a bit, swap mounts, then do everything in reverse.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Wow i’m surprised given all the great reviews. This must be one of the greater reduction units but still, not the most buttery smooth shifting. Perhaps i need to try different trans fluid. Also have a new weighted oe knob ready to go in.Originally posted by Slideways View Post
Edit. Took the boot off, pretty sure it(the boot) was just installed wacky.
No branding on the shift lever that I can see. I also inspected the stock parts that were removed, which only included the lever and selector rod. So that leads me to believe this is just a ssk lever and selector rod replacement, which would explain the notchy crappy shifting.
Build thread: link
On closer inspection in that picture, it looks to be UUC and not Autosolutions. I had to see the shift arm which didn't show up in the earlier pictures.Originally posted by bavarian3 View Post
I dont see the set screws on the shift carrier.Originally posted by Slideways View Post
https://www.ecstuning.com/b-scratch-...SABEgLHqvD_BwE
Should the sunroof glass perimeter seal be able to be installed as once piece or is it sometime required to cut it to fit?
My original seal came off as one piece but the new seal I had to cut, it was too large so I cut ~1/2" at the seam for it to fit. I'm sure it will seal fine but I would prefer it to be one continuous piece if possible.2004 Silbergrau Metallic 6MT
the 3 screws are there just hard to see in the pic. i do think it's a uuc though their site offers very limited description and pictures of what their kit includes. looks like an autosolution kit is in order.Originally posted by jayjaya29 View Post
i didn't hate it on my e36. shifted like butter with new detents. but man this setup on the e46 is nearly undriveable.Originally posted by BMWE46M3 View PostIf it sucks it must be from UUC.🔹 2001 M3 Laguna Seca Blue
Build thread: link
