Originally posted by jet_dogg
If you mean the exhaust manifold studs those are M7X1.2004 Silbergrau Metallic 6MT
I like to use this stuff on my o-rings, but not 100% sure if it's okay for fuel injectors. I think it should be fine since it's non-curing silicone but maybe need to do some more research.Originally posted by Fresh1179 View PostWhat is the recommended lube for fuel injector o-rings? I have seen everything from spit,oil,Vaseline and so on and so forth. About to replace my injectors here soon. Thanks!
Oh yeah, thanks again for the exhaust man!!!
Sorry yes that's what I meant, thanks for reading my mind 😎Originally posted by Cubieman View Post
If you mean the exhaust manifold studs those are M7X1.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
Cleaning should be just fine.Originally posted by AWE46M3 View PostICV - replace it, or is cleaning it good enough? Getting parts together for my airbox install and want to refresh the ICV and TPS while I'm at it.
I wonder - does the sensor end that plugs in ever go bad? I likely have the original and don’t want to have to remove the airbox to get to it. Is the ICV known for failing electronically or just the mechanic issues caused by gumming up?Originally posted by Cubieman View Post
The ICV is really just known for getting gummed up, you can just brake clean it.Originally posted by AWE46M3 View Post
I guess I have never heard of anyone replacing them for preventative reasons but I'm a guy that has 1/2 a car in parts I'll likely never use down in the basement so I now all about just replacing things.2004 Silbergrau Metallic 6MT
hahaha! man...all these parts going NLA has me buying and hoarding parts in case I need them down the road. Thanks for your input 🤝Originally posted by Cubieman View Post
Looking for the P/N for this phillips head plastic screw/rivet that secures the bumper to the lower wheel well covering.
Cannot seem to find this listed on real OEM.
Considering importing a car from Canada. Anyone have experience importing or recommendations for a import broker?2001 TiAG M3 - 6mt Coupe, Anthracite Impuse - SOLD
I don't think that's the OE part? Usually its just one of these 51118174185Originally posted by Cubieman View PostLooking for the P/N for this phillips head plastic screw/rivet that secures the bumper to the lower wheel well covering.
Yes, but I suspect you don't mean the actual tower, do you mean the bar/brace?
If the car is on the ground, you should be able to preserve camber/caster while swapping the brace.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I will be replacing my diff bushings soon. Does anyone have a parts number last handy of the diff bolts & nuts I will need to replace while doing the bushings? I looked on realoem and didn’t find much success, I also remember some of the bolts being updated which was not reflected in realoem.
